I have a Mitsubishi WS65907; it does not display the full picture - the edges are cut off especially on the left side of the screen. The resolution seems OK, the full picture does not seem to be displayed.
SOURCE: Shrinking Picture
Triangular shadow in the left corner is a light engine problem,,, not available!!!! This unit can be repaired by Electronic Services in Fort Smith AR. (479 7835930) if you can remove it and ship it to them..
SOURCE: Picture is off center to the left by 9.5 inches
you need a new light tunnle cost about £70 but whoever you get to replace it wil charge about £140 labour
SOURCE: Mitsubishi WD-62628 Projection TV Failure
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
SOURCE: Picture size decreases and increases with non uniform edges
Common problem. If its warped but stationary I would agree its most likely the convergence chips.
If however it shrinks/expands its most likely the opt chip. You can get a repair kit from www.magnavoxhelp.com for this common problem. Other symptoms may be no audio/video but this problem typicaly happens after you encounter the 1st problem ( shrinking/expanding video)
SOURCE: Mitsubishi WD 62725 -picture slightly tilted from right to left
Thats a common adjustment called the TILT adjustment. You can get the service manual emailed to you from the following link which will explain how to doo the Tilt adjustment. Heres a link to the proper manual for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/wd52525-dlp/cName/mitsubishi
