Question about Dell 922 All-In-One InkJet Printer
Dell 922 My DEll 922, 9WJG371, Printer Power light is on, but blank display, will not power down, nor when open center ink carts. power adapter shows 28.6 volts with a multimeter. Dell doesn't know if this value is correct! Dell says new PN for adapter is R4674 $11 US Is this the source of my problem? Thanks JJ
Yes I have cold started afew times already. I suspect the Adapter, because there is not much else there to swap out.
Posted on Feb 11, 2007
    Novelist:
    Champion:
  • 202 Answers
Have you unplugged it from the wall for a few minutes? That will flush the memory and give it a clean start. Below is some other info I found. Power supplies, use technology to convert the AC input to lower DC voltages. The typical voltages supplied are: * 3.3 volts * 5 volts * 12 volts Good Luck, Tim
My Dell All-In-One printer is not printing at all and the paper comes out blank. I need help.
Ensure that the printer power cable is firmly connected to the printer and the electrical outlet
Determine if the printer has been held or paused
  1. In Windows XP, click Start® Settings® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Double-click Dell Photo AIO Printer 922, and then click Printer.
  2. Make sure a check mark is not next to Pause Printing. If a check mark is next to Pause Printing, click Pause Printing to deselect it.
Check for flashing lights on the printer.
Ensure you installed the ink cartridges correctly and removed the sticker and tape from each cartridge
Make sure you loaded the paper correctly
Jan 19, 2011 | Dell 922 All-In-One InkJet Printer
Power button light is permanently on but printer is not working
Remove printer cable from pc. Remove power cord from printer. remove cartridge clean it and re-install. connect again it will work fine.
Jun 20, 2009 | Dell 922 All-In-One InkJet Printer
Print head problem
Do a reset:
Dell Printer reset
1. With the power on,unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket.
Dell Printers
To run a nozzle clean, perform the following steps:
1. Verify the All-In-One Printer 922 is powered on and connected to a computer.
2. Verify that the paper support (input tray) has clean, plain white paper loaded.
3. Press the Menu button.
4. Press the Down button until Mode: Maintenance appears on the LCD screen.
5. Press the Menu button.
The Dell 922 Maintenance Menu appears on the LCD screen.
6. Press the Down button until Clean Cartridges appears on the LCD screen.
7. Press the Start button.
The AIO 922 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 02, 2009 | Dell 922 All-In-One InkJet Printer
Blank display screen
Hi martalyn,
I sorry to inform you that the situation you describe is an indicator of an internal power problem with the printer. This is not something a consumer can fix on his or her own. If your printer is under warranty, contact Dell - they will most likely replace it. If not, I'm afraid you'll have to buy a new printer (since the cost of fixing a printer far exceeds the cost of simply buying a new one).
I wish I could offer you better news - please let me know if your printer's symptoms change, or if I can be of any further assistance.
Kind regards,
H2H
Nov 24, 2008 | Dell 922 All-In-One InkJet Printer
Problems with Dell 922 All-In-One InkJet Printer
check to see if the ink cartridges are installed properly, or if there is a paper jam. If not unplug it for 2-3 minutes, and try using it again.
Jan 09, 2008 | Dell 922 All-In-One InkJet Printer
No print
replace cart. first with original.
Dec 18, 2007 | Dell A920 InkJet Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 AIO printer~~ does not power on when press power button all cords are connected ~~ is there a power supply in the power cord that fails ??
I had a simalar problem. On the back of the printer where the power cord plugs in it is connected to a power adapter. The adapter was burnt out. the power adapter slides out. Mine was melted easy to see. I ordered one from dell. If you do order one from dell make sure they send you the correct part. They sent me the wrong part the first time. There customer service dept. ha gone way downhill.. Regards Frank
Oct 02, 2007 | Dell 922 All-In-One InkJet Printer
Changing language dell 922 printer
To change the language on the Dell 922's display, turn on the printer, then press and hold the Power and Cancel buttons at the same time for about 10 seconds. The language choices will then scroll across the LCD press the up or down arrow key till english appears, then click Menu.
Sep 15, 2007 | Dell 922 All-In-One InkJet Printer
No Power, Dell 922 Doesn't work
There might be a a second switch that you might have to turn on, if not, try plugging it in again and your wiring to the printer and PC.
Nov 12, 2006 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
141 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
