I have a magnavox dvd recorder, model # ZV420MW8, that I cannot hook up to my comcast cable box, so altho the drawer will open and its showing that its loading on the dvd itself, there is no picture on the tv. Its an inline set, so do I need the S Video cable or the RF? Thank you, Marti Parks
    Scholar:
  • 38 Answers
Please clarify how you have the dvd connected right now. You should use the video output out of dvd and into the t.v. That dvd don't have rf out. You have to match component or s-video or composite with what your tv has. We can't help because I don't know what inputs your T.V. has. You may have to come out of the cable box with video-outs/audio then into the dvd and then out to the t.v.. Remember, you MUST come OUT with the box and IN to the dvd, then OUT of dvd and IN to the t.v. Always out/in/out/in. You have 3 different formats. Depending on what the t.v. has is the one you will use. Composite is yellow cable...good then s-video used black cable with pins inside....better and Component uses 3 cables red/green/blue....best. Don't forget to also hook-up your audio signal too. This should be enough info for you to get it going. Remember too that you will need to set the dvd on your input the cablebox is on to feed the signal through. You can only record what the cable box is tuned to. That should do it. Good-luck.
Posted on Dec 05, 2008
Is my Magnavox 1T HDD rECORDER COMPABILE WITH cOMCAST cable Box ?
If your Comcast box has a composite output, you'll be able to record SD shows. Use RCA composite video and audio cables between the box and the recorder. You'll have to set the box to the channel you want to record and leave it on. Then set the HDD/DVD unit to record from video input (L1 rear, L2 front) for the appropriate length of time. The manual explains this. The manual is available from Funai who built the unit with the Magnavox name: http://funaiport.com/upload/MAGNAVOX/Manual/MDR537H_EN_OM.pdf . See pages 19 and 42. If your TV and/or cable box only have a limited number of video inputs/outputs, you may need to daisy chain the composite video cables from the cable box to the DVD/HDD unit's video in. Then connect another composite cable from the DVD/HDD video out to the TV.
This Magnavox unit can only read analog (NTSC) cable video signals without a set top box. You will not be able to record a show and then watch another with the cable box.
I hope this helps.
(I know that my cable system's box has a composite video out. So it does work with most of the Comcast boxes. Many of the manuals are available here: http://customer.comcast.com/help-and-support/cable-tv/cable-box-user-manuals/ )
Sep 25, 2014 | Televison & Video
How connect Magnavox DVDR to Comcast Cable Box ?
You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
Sep 25, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
How do I change VCR recording speed on the Magnavox ZV420MW8
If you have the manual it is on page 79 (Press Rec Mode There are two speeds SP SLP it will toggle between the two.)
You can download the manual at http://www.funai-corp.com/6pdf/om/ZV420MW8.pdf
Jul 04, 2011 | Magnavox ZV420MW8 DVD/VCR
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do i connect my magnavox zv420mw8 to my cable boxconverterand modulator
the cable from the wall is to the cable box in....(do have monitor) cable box out to tv coax in...dvd / vcr & audio outs to tv ins....and tv outs back to dvd vcr audio in....tv is on ch 3 for cable...look for your dvd /vcr or aux ch when want to look a dvd or vcr...now set the dvd to ch 3 settings and cable broadcast...your cable box will determine what you record....note HBO may not record on DVD, but will on VCR tape
May 15, 2010 | Philips Magnavox DVD/VCR Dual Player
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
NO AUDIO ON MAGNAVOX ZV420MW8 RECORDING SECTION
Are you using AV cables (Red, Yellow, White).
One of your AV cable connections may loose or disconnected.
I hope this solution is helpful. Please remember to rate this solution.
Feb 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Zv420mw8 magnavox vhs to dvd recorder
I have lost my remote to my Digital Video Disc Recorder with Videeo Cassette Recorder #ZV420MW8. I would like to know how to go about getting a replacement. Thank You, Diane Wotton dianewotton@yahoo.com
Oct 31, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV420MW8
This recorder only records inline. This means that there is no channel on recorder. It records whatever your satellite or cable box is showing. You'll have to change the channel on that.
I don't know that this will work for timed recording. You'll have to make sure that your cable/satellite is on and set to the proper channel before you leave. This wont work if you're recording multiple shows on different channels while you're gone. In that case you may need a different recorder.
Mar 16, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
