Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Thermometer or temp gauge not working - not cooling at all
I had an appliance guy out in March for the temp not keeping steady the whole unit went warm, freezer and all. He replaced (for $329) what he called the 'computer' and it's been doing the same 'going warm and defrosting' for 2 months. I unplugged it for 48 hrs, plugged it back in and it was fine. There is a buzzing and a click sound in the back near the water intake but otherwise was working fine. This past week, it thawed again and after unplugging and plugging back in, nothing changed. I can't imagine for the cost of this that I have to replace 'the computer' again within the same year. Please advise! Thanks! Vikki
  • 50 Answers
If it was replaced within a year and you paid that much it seems that it should be under some sort of warranty. if so they should come out and fix it for free. the computer itself you can buy for less than a hundred dollars. but it could be a thermostat problem in which case could be less than 30 dollars.
im attaching a link to a website where i have the parts list and prices where u can buy direct. if it is the computer again maybe u can buy it direct and have him just install and save the middle man price for the part
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174973
Posted on Dec 05, 2008
Why is my 2003 impala running cold when i run the car it never reaches it's normal temperature
It is likely that the thermostat is stuck open. Remove and replace. They are very inexpensive.
Mar 14, 2015 | 2003 Chevrolet Impala
I have a 2008 Chevy Colorado and today my temp
when a temp gauge drops to cold ,it indicates a problem in the cooling system
temp gauge sender units need water to activate the resistance that makes the gauge read so a falling gauge indicates no water around the sender unit --- air lock in the system--faulty wire connection to the gauge sender unit
the ac unit is not connected to the temp gauge so there may be another separate problem there
the temp sensor is an entirely different unit to the temp gauge sender unit and the short term working would be from an altered coolant level from changing that sensor --air lock in system
the temp sensor connects to the ECM to activate the fans and monitor engine operating temp so as to keep the air/fuel mixture exact for the engine conditions
the temp sender unit just makes the temp gauge read
a faulty thermostat will either be stuck open and the engine temp will take a long time to rise or it will be stuck closed and that will cause an overheat very quickly
Sep 11, 2014 | 2008 Chevrolet Colorado
When jackaroo 1988 is motoring where does the needle in the temperature gauge normally be
If your temp gauge has only the cold (C) or hot (H) letters then the operating range would be the width of the needle under 1/2 way between c and h. If it remains steady at slightly over 1/2 way that would be just the setting of the gauge. How to get to know where the needle would sit at a specific position in relation to water temp. Do the following
Remove the temp sender unit and attach an earth wire to the body of the unit to earth. Place the sender unit in a container of water up to the threads .Put a mercury thermometer in the container beside the sender unit Apply heat to the container and watch the gauge needle move in relation to the thermometer reading. Operating temp will be about 80 degrees C on the thermometer and that would be about 1/2 way on the gauge.
Apr 20, 2013 | Cars & Trucks
Hello, I have a 1995 Audi 80 V6 that keeps overheating. As a cheap temporary solution my mechanic bypassed the aircon which seemed to work at the beginning but the problem has returned. There seems to be...
Low engine coolant can keep temperature sensors from working correctly. Air or combution gasses being forced into the cooling system from a blown head gasket or cracked head can cause the same symptoms.
If you want to know if the temperature sensor is working, you must first be certain that the rest of the cooling system is working and only then can you determine if the sensor is "lying" to you. The actual engine temperature should be checked with an infrared thermometer and compared to the temperature sensor data in the onboard computer.
There is a coolant temperature sensor for the computer and there is a separate coolant temperature sending unit for the gauge. Comparing the two and verifying with an infrared thermometer is the best way to figure out what is going on.
Apr 07, 2012 | 1993 Audi 80
In "Heat" mode, the displayed
You have something else going on. The tstat is probably sensing a remote temp. Is it hanging on the wall next to the furnace? Maybe warm air is coming from the furnace closet and fooling the tstat? Or an appliance or TV located too close to is, and heating it? If its quickly increasing the temp during unit operation only, it may be sensing air through the hole in the wall, directly being the tstat, where the wires come though to connect to the tstat. Try plugging that hole and test it. Or possibly the ceiling register that supplies air is facing the tstat, warming it by blowing hot air directly at it. If that's it, remove the grille and face it away. Not sure what else it may be. Hope this helps!
Mar 25, 2017 | EdgeStar Portable Air Conditioner ...
I RECENTLY REPLACED THE THERMOSTAT IN A 1996 FORD EXPLORER 4.0 4WD. THE HEAT WAS WORKING FINE AND THE GAUGE STARTED MOVING UP TO HOT AND THEN BACK DOWN TO THE COOL MARK WHILE DRIVING. AFTER COMPLETION I...
i wonder if possibly a defective thermostat, that it is sticking open.
to bench test thermostat place in a pot,if you have a candy thermometer all the better ,place in cool water and bring to boil checking temp.it should open alittle at a time until being fully open at what ever temp it is rated at
then slowly add cold water and it should close in a similar fashion
Nov 08, 2009 | 1996 Ford Explorer
Temp. gauge does not work at all.
You need to perform some electrical troubleshooting to see if the temp gauge circuit is getting voltage to the sending unit and the gauge; and/or if the gauge itself is faulty.
More info? Let me know...
Charlie
Aug 14, 2009 | 2005 Chevrolet Impala
Can't get freezer to cool below 10deg F
For Olson- most combination units have a diverter that allows you to balance the flow of frigid air between the fridge and freezer. It may be located in the rear of your unit since the main cold air flow is done there.
Rockitman - not sure which temperature scale you are using - Olson specified 'F' and normal ranges for the refrigerator would be +35 to +45 degrees and freezer temps are recommended as -5 to 0 F. +10 degrees F wouldn't ensure that food would be very well preserved. Indeed, foods with any amount of salt in them may age at +10.
Feb 09, 2009 | KitchenAid KSSS36QK Side by Side...
Cooling system of motor don't work properly, above 80 degree Celsius then it start to work!!! What's wrong??
Thermal temp switch usualy located at the bottom of the radiator or the temp gauge sensor is sending wrong temp signal to gauge. Have you put radiator thermometer in radiator to test that its all working when its supposed to?
Oct 30, 2008 | 1992 Mercedes-Benz E-Class
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
74 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
