Question about ASUS P4P800 SE (890552603657) Motherboard
My young son switched off my computer at the wall and since that my comp wont power up correctly , no image on monitor , switches itself off , beeps irreguarly.I have checked all connections and replaced the video card with no joy.
  • 903 Answers
Have you checked the ram?
Take out the Ram, if you have more than one stick, then replace them one at a time and power up with on first if it works then add the other one. If it doesn't work, remove the first stick and replace it with the other one and power on again.
This could be caused by bad or dirty ram. (while the sticks are out clean the, with a soft dry paint brush and the slot that they fit into, and when you replace them, make sure that they are replaced gently bur firmly and click back into place)
I hope this helps
Posted on Dec 05, 2008
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
It display every thing for few second and get off display itself but not power when i switch off on then it come back then again get off
Good luck.
Jul 18, 2014 | Computers & Internet
Monitor light up then shut down itself
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 11, 2014 | Sony SDM HS93 19" LCD Monitor
Monitor wont come on on power spec model 7124
Probably your computer needs newer monitor (the monitor's frequency can not accommodate the video card's required frequency). Please post the details info of both your 2 computers and the monitor.
Mar 03, 2014 | Computers & Internet
My converter does nothing,power light is on,but no picture,nosignals,nothing.what's wrong;
If, when you first turn on the power, you hear the hard drive spinning or possibly a beep, see any of the other lights briefly flash, or passably hear the fan start then the likely cause is the video.
  1. Check that the video cable is securely screwed into the computer
  2. Check the video cable going into the monitor too. Some manufactures have removable cables on their monitors.
  3. Be sure that the monitor has power, most monitor power switches have indicator lights either built-in the switch or near to the switch. Generally it's green
  4. Try your monitor on a friend's computer to make sure it works. Or you could try or your friends monitor on your computer too.
If it's not your monitor it could be your video card.
a) TURN OFF THE SWITCH AND REMOVE THE POWER CORD (either from the computer or the wall).
b) Open the case and reseat the card. That means that you will have to remove the video cable, remove the screw that holds the card in place. Pull up "gently but firmly"
c) Once the card comes out carefully reinstall the card into the same slot. Use your eyes to be sure it's lined up squarely and push it in. It should be clear to you when it's seated. It might take slight wiggle to get it in, this is normal.
d) Put the securing screw back in, close the case up and reconnect all cables and the power.
If on the other hand when you turn on the power switch you don't hear any or see any other lights. The first suspect would be the Power Supply. Replacing a power supply is easy enough on most machines, The problem is that getting the correct Power Supply can be tricky. There are a few types and some manufactures have made it so that only that manufacture
Dec 21, 2010 | Computers & Internet
Just now i shut down my computer normally, an hour later when i tried switching it on again i cannot, the monitor dosent show any image, it even not shows the BIOS, the fan tuns just for a while and then...
It sounds like a hardware problem. Check the obvious like the power cables and plug it into a different wall socket to make sure that isn't the problem.
Does the computer beep when it starts up. The pattern of these 'POST' beeps can help you determine the problem. However if the computer doesn't beep, doesn't activate the BIOS and the hard drive doesn't spin up (with the HD light flickering) then you either have a fried motherboard or processor. Not an easy or cheap thing to fix.
Sep 03, 2010 | Computers & Internet
It wont power up bro
It is possible that your monitor is on a GFI switch. These switches turn off if they detect a problem that could incur a shock, or if they are getting worn. Check if there is a power outlet in the same room with a red and black switch. If so, push the reset switch, typically the red one.
Your monitor may also be on a switch activated outlet. Is it plugged into the top outlet? See if a wall switch nearby controls the outlet. then try turning on your monitor.
Is the surge protector your monitor is plugged into turned on?
Check the cord on the back of your monitor. It is possible it may be loose. Plug it in all the way.
Some Viewsonic monitors have a power pack that is not inside the monitor case. Check the wiring between it and the wall and between the pack and the monitor for frays.
May 12, 2010 | Computers & Internet
Monitor directly enter into power afe mode wen we
turn off the cop and unplug all the cables and open the comp tower and remove all memory chip and turn on the comp by plugging just the power cable and leave the comp on for 2-3 min and the comp will beep and thn turn off the cop and pull the power out and put the memoy chips back in the comp and plug all the cables asnd then turn on the comp anf the issue resolved le me know if any problems at tauseef.razzaq@yahoo.com
Memory Installation Guidelines
Sep 18, 2009 | Computers & Internet
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
Asus K8N-LR power problem
This is a problem within your ATX power supply . Better to get it repaired or replaced , otherwise each switch-on surge would damage your comp components eventually .
Apr 14, 2008 | ASUS K8N-LR Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
35 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
