Question about Orion Car Audio & Video
Old schoool orion amp 250-hcca
I just inherited an old orion 250hcca amp
i dont know what wires are what other than hot and ground
any help on wiring would be great help thanx
  • Perry Babin May 11, 2010
    Do you know if it's a 1st or 2nd generation?
Wiring Codes for SX and HCCA
Orange = Right Positive
Black/Orange = Right Negative
Yellow = Left Positive
Black/Yellow = Left Negative
Blue = Remote Turn On
You can remove the bottom of the amp and the colors can be deciphered as to which goes to which pin in the plug. Go to this link on AmpGuts for a reference.
http://www.ampguts.realmofexcursion.com/Orion_HCCA250/
And here is a link where you can buy a new plug on ebay for $25.
http://cgi.ebay.com.my/ws/eBayISAPI.dll?ViewItem&item=110093583828&indexURL=
Posted on Dec 08, 2008
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Black/ Orange = Right Negative
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Orion 275g4 Hcca amp
this actually could be your amp...try turning the gain down slowly and you will hear the bumping either stop or become morelike music background thanmusic foregroud. i had this problem with an older amplifier and i fixed it by getting a larder power/ground wire size and decreasing the gain a little.
Sep 03, 2007 | Orion HCCA 275G4 Car Audio Amplifier
Car Audio & Video Logo
563 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
