Question about Sony KV-29LS60 29" TV
My Sony KV29LS60E shuts down after a minute or so,and then nothing is lit
My Sony VPLHS-20 has original bulb, now just shut off 50 mins into the SuperBowl. No fault light, in fact, no lights showing on the display at all. Bulb has around 1800 hours. I waited 10 minute, red...
Pretty sure it the bulb as most are rated at 2000 hours; but also check for full air flow - clean filters etc. Bulbs can run hotter as they age, so air flow is more important, because there is an inside heat sensor that will shut the machine down.
Feb 09, 2011 | Sony VPL-HS20 Multimedia Projector
My sony rdr-gx355 will not turn on. The blue HDMI light is lit up but nothing else will work
Same here. I'm trying the "unplug and wait 40 minutes" solution like some of the Sony Blue-Ray solutions.
Nov 03, 2010 | Sony RDR-GX355
Flame does not stay lit
check the vent hose first...sounds like it is shutting off from the sensor that watches for that. It might also be the coils on the gas valve are going out.
Oct 25, 2009 | Kenmore Dryers
Gsw heater pilot stays lit, but when the main
It sounds like your main valve. The diaphram may be loose fitting or it has a small leak.
Oct 03, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
Software shuts down. says not responding. has
hi,, it can be an problem with your RAM,,mostly,, or else can be your motherboard / processor, but first you have to try replacing your RAM..with other ones
Sep 27, 2009 | Sony Vegas Movie Studio for PC
Oven malfunctioning, not getting hot; smell of "gas"
Check that the pilot is lit., If not, light it after gas is shut off for 10 minutes. Then turn to pilot, hold down, light, keep holding down for exactly 1 minute, then turn gas knob to ON and you should be good. If gas shuts off, then valve is bad.
Sep 16, 2009 | Kitchen Ranges
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Nothing displays on screen
the bulb maybe burnt out, I had a similar problem only no audio. The odd thing was that the lamp light was not lit indicating the bulb was burnt.
Dec 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony TV kv29LS60e - over voltage protection
it is power supply problem. your oscillator for switching ckt or switching output failure. if you are not tech person call him for help. it is not a major problem good luck.
Oct 02, 2007 | Sony KV-29LS60 29" TV
Sony KV-29LS60 29" TV Logo
456 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
