Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
My kenmore electric oven says locked with and F5 code on it.
My Kenmore electric oven sasys locked with an F5 code. I need help unlocking it. i PRESS EVERYBUTTON BUT NOTHING UNLOCKS IT.
I unplugged mine for a few moments and voila! Dinner was finally mine! m
Posted on Dec 06, 2008
Model 40121 the oven is locked how do i unlock it
Hi!
For unlocking the Kenmore oven, please press and hold the STOP/CLEAR button for 3 seconds.
Please let me know if it helped
Best regards!
Aug 09, 2011 | Kenmore 40192 / 40199 Electric Single Oven
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Electric kenmore oven showing an F3 then F5 after it heats up
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$5
Nov 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven showing an F3 and later F5
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Flashed F5 when temp is heating up
HI, this code is signaling that your temperature sensor is malfunction. it will result in major damage to the control board and sensor wiring harness if it is not corrected soon. the will allow for high temps during the cleaning process that will ruin the ovens control circuit board.
replace the oven temp sensor soon.
May 19, 2009 | Kenmore 47834 / 47832 / 47839 Electric...
Kenmore ultra bake oven is locked
The manual is located at the back of your oven. If your oven is against a wall, pull it back, not too far, and you will see a manual taped to the back of it. From there, it will provide you with answers some employers won't know. If it's not there, sorry, you're outta luck!
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
KEMORE OVEN SELF CLEANING
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F5 error on a Kenmore Gas Oven
f5 is a door lock code there is a problem with your door latch. its should lock the door at a crtain temperature and its not.
Mar 31, 2007 | Kenmore 30169 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
330 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
