Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sensor lights not working on door opener
I can open my garage door with the remote just fine, but it will not close the door. When I try to close it from the button inside the garage I have to hold it down until the door is all the way closed, otherwise it starts to go up again. However, when I want to open the door from inside I can just press the button and it will open without having to hold it down. Would like to know how to fix this problem, is a pain when I leave the garage I have to go park in front of the house, go back in the house and into the garage to hold down the button to close the door. Can you help.
  • 2 more comments
  • MattjMunson Dec 05, 2008
    totally have the same problem.  Remotes will open them but not close.  Door clicks like the light sensors are being blocked.
  • a3guy Dec 31, 2008
    I have the same problem,except it is intermittent. Some times it works and some times it won't. I have checked the alignment of the sensors and checked the wires to the opener. Driving me crazy.
  • rnno1 Apr 28, 2009
    I have the same problem but have noticed that one sensor is green and will not light if I block it, while the other sensor is continuously yellow!? Do I need a new sensor/
  • Anonymous Apr 29, 2009
    Same problem as Matt. Let me try yo realign the sensors.
    Problem Solver:
  • 6 Answers
If the sensor light or receiver gets kicked, it can be knocked out of alignment. If it's not aligned, it will act as though it is blocked -- in other words it will open, but not close.
I fixed my buddy's opener not long ago -- you should have two parts of the sensor, near the floor at the bottom of the door. One is an infrared light, the other is a receiver. The receiver should have a little LED on it. This glows green when it is receiving a clear signal from the other side. If your's is glowing red when you can see that the path is clear, try adjusting the aim of the infrared light. You should be able to gently move the light from side to side until you see the LED on the receiver glow green.
Posted on Dec 07, 2008
3 Suggested Answers
  • 3197 Answers
SOURCE: can open my garage door
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering ever so slightly. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Posted on Jun 27, 2011
  • 3197 Answers
SOURCE: I can open my garage
Make sure your door sensors are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have either a bad sensor or the wiring to them.
Posted on Sep 07, 2010
My garage door opens fine, just wont close with remotes. Lights just flash. I have to use the opener in garage and keep the button pressed in till the door is fully closed or it will reverse.
Clean both safety sensors lens located at the bottom of the garage door frame. Make sure both sensors led lights are lit. If not they are out of alignment and you will have to loosen the wing nut on the sensor that is lit and move it, trying to get the other sensor to light.
Jul 27, 2011 | liftmaster Garage Door 1/2 Hp
My fixed garage door opener opens fine, but only closes if it is held down. My remote garage door openers do not work at all. I replaced the sensors and they appear to work fine. I tried to reprogram the...
If the sensor is working right, that leaves the downward force sensor tripping. First check for track obstrucions by manually moving the door with the lift disengaged. If door works without excessive force, then increase the force sensor of the lift a bit.
Jun 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
The sensor lights are steady. The opener cycles fine withouit the garage door connected. Everything worked fine until yesterday. I hit the open remote and the garage door did not open. I hit close and it...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. Also check the door springs. One of them could be broken.
May 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote opens door but will not close door (Liftmaster)
If when you try to close the door with the remote the main light flashes 10 times and the door reverses to the open position you have a door sensor problem. Usually it is because one of them has been bumped and is no longer pointed at the other one. If they are pointed properly they will each have a small light that is lit and not flickering. Tweak them a bit. If this doesn't work and the lights are not on you most likely have bad sensors.
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Main light on will not come on when door is opened/closed
For some reason, the bulbs I tested that worked somehow didn't work correctly when inserted into the door opener. We opened another set of bulbs we purchased and what do you know, the light now works. I don't fully understand as the other bulbs did work just not in the garage door opener.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Remote
find attena and point it to your door if this does not work try adding a piece of wire to attena and making it longer also always check batts...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only works partly
some thing blocking sensor or laser is not in proper alinement
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door not closing all the way
what brand. you described three sensor lights/ Craftsman/Liftmaster have two, Sounds like saftey beam problem,
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close with remotes
Yeh, read manual. Do both sensors have led lit. try aligning. you have safety beam problem,
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,853 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
