Question about Air Tools & Compressors
Wiring diagram need the wiring diagram for a binks aircompressor model # 33-1259. basically any info about what the motor is... is it a 2 stroke or 4 stroke or neither.
  • 98 Answers
If theres wires coming out of the motor it is more than likely an electric motor , If it is a gasoline engine it is a 4 stroke engine
Posted on Jul 21, 2009
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
Wiring diagram for 3.6HP parsun outboard motor 2 stroke please
sorry but here in US never heard of that Make.
Oct 31, 2014 | Boating
Valve clearance for suzuki TF125 pls!...many thnx
hey mate, have a look on google. just type valve clearance for your year make and model of bike.
Oct 11, 2014 | 2005 Suzuki TF 125 Mud Bug
I need an engine diagram to help repair a Kirby tecumseh motor
Go to youtube On line overall kirby tecumseh moyor
Nov 21, 2013 | Garden
92 Yamaha over heating make rumbling niose then
Sounds like you need an experienced motor mechanic
Aug 18, 2013 | Yamaha Boating
Need wiring diagram for T104M 208-277v Mech. Time Time Switch
Here is the basic instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Below is a larger and better diagram of a 240V connection Terminal connections are White to White on 3 & 4 Black to Black on 1 & 2:
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
More info: http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
I am assuming you have the 240 VAC clock motor so the clock timer motor wires are connected to terminals 1 and 3.
If you only have the 120 VAC clock motor the wires will be connected across terminals 1 and 2.
Thanks for choosing FixYa,
Kelly
Jun 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
I am trying to find a manual for a binks 2001 spray gun i am having trouble figuring out where the o ring number 7 goes
I looked up same gun. I think I googled "binks model 2001 spray gun" and I got a pdf with all info and diagrams. On the available websites, I looked for the one that looked like official Binks site.
The PDF # I got is 77-2316R-14.pdf. It shows that #7 o ring
Nov 05, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
Need the firing order 7.3 power stroke
firing order is 1-5-4-2-6-3-7-8
here are the diagrams. I don't know how they will show up here. Post back if they are not large enough. include you email if so.
EVEN 2/ 4/ 6/ 8
ODD 1357
you may also need this one for the fuel line heater & glow plug relay
Apr 30, 2010 | 1997 Ford F350 Crew Cab
Need a wiring schematic for a dual voltage masonry saw motor. it s a baldor motor on a target saw
http://us.husqvarnacp.com/
drop down menu "service"
click "service literature"
click "old target, dimas, partner literature"
enter model number
pdf has basic wiring diagram page 4 or so
Dec 12, 2009 | Target Portable Masonry Saw PS1411S...
I have a Speedaire model 3z492 air compressor. The manual is gone and the information plates as well. I need to know if this model is cappable of maintaining 100 psi @ 10cfm? Any ideas?
Here is info I found "Pump:
Two Stage, Cast Iron, Compressor Pump, 5 HP, 17.1 CFM Maximum Free Air Flow At 175 PSI Maximum, 2 Cylinder, Oil Capacity 2 Quarts, Pump Speed 685 RPM, Bore Size 4 3/4 x 2 1/2 Inches, Stroke 3 Inches, Motor Sheave Diameter 6.75 Inches, Flywheel Diameter 16 1/2 Inches, W 18, Depth 16 1/2 Inches, Height 22 1/4 Inches, Outlet 3/4 Inch NPT, Mounting Holes 8 3/4 x 5 3/4 Inches"
Nov 08, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
394 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
