Question about Canon imageRUNNER C3200 Copier
Canon Imagerunner color 3200 copier
I just bought a used c3200 copier and trying to connect it to my network. I set the IP address using the control panel. I cannot ping an address on my network nor can I see the printer address from the server. I am using s atraight through network cable. Do I need to us a cross over cable? My network uses a 10/100 switch.
  • OmKar9090 Dec 22, 2008
    I have a similiar problem. I can ping it, but the RUI will not open. The option is selected on the Copy (Remote UI)... IP and DNS are correctly setup because I can access the Fiery WebTools. When I click on 'Remote UI' it doesn't open.
  • Ian  Auret
    Ian Auret May 11, 2010
    The straight cable will work.Make sure your copier's IP address is in the same range as your network.Try to ping again.Sometimes it take some time before the network see the copier.
Hwo much is this
Posted on Aug 02, 2009
  • 67 Answers
You need to load the copier drivers into your server you can down load these drivers from canon website /or your network outlet is not setup
Posted on Dec 06, 2008
Ip cannon image runner 3200
Additional functions
System Settings
Network settings
Tcp-Ip settings
Sep 11, 2010 | Canon imageRUNNER C3200 Copier
Wanting to connect pc to a Canon ImageRunner C3100. Anyone have any ideas on doing this?
hi first u have to vearfy that yours irc3100 have a network card if yes then you have to
1.download latest driver for irc3100 from canon ofical website.
2. you shud have a network cross cable to connect directly from your pc if you dont want conect directly you want to conect throug yours local network in that condation you can use normal network cable,
3. you have set IP address on yours irc3100.
4. just connect networ cable and install driver on pc.
thats it enjoy
thanks
May 13, 2010 | Canon imageRUNNER C3200 Copier
I lost my network connection when I changed my network router. How can i reestablish the connection
pree the star bottom in the key bord
then
system setting
network setting
tp/ip address
input the TP/IP address as in your pc
Examp.:
copier:
172.16.1.160
255.255.0.0
pc:
172.16.1.159
255.255.0.0
then restart the pc and the copier
Apr 08, 2010 | Canon imageRUNNER C3200 Copier
Tried the solution to set black as the default color on the Canon ir c3200 that was on your site, it says to set as B/W on screen, only gives Auto Color Select, Full Color and Black as choices. Says to go...
might be able to do this through your remote user interface {the copier ip address} go to internet expolrer and type the ip into the address bar and look around for settings under additional funtions
Mar 26, 2010 | Canon imageRUNNER C3200 Copier
I HAVE ONE IRC 3200 AND I DONT KNOW WHAT DRIVER INSTALL FOR SCAN AND PRINT, I HAVE WIN XP
Go to http://www.usa.canon.com
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
IR C320N scaning with MAC OSX
Use the Irc 3200 drivers on the Canon USA
Color imageRUNNER C3200 : Drivers & Downloads
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2269&modelid=8927
Feb 08, 2009 | Canon imageRUNNER C3200 Copier
Canon ImageRunner Missing Menu Functions
Fiery..
you would need to acess the fiery network controls from the touch panel. on the copier, reset up the ip address etc. reboot the fiery.
Fiery are a bit different from the standard acess to a nic card on a machine. Again I really am not familiar with Cannon. Thou I would recomenend searching for a Fiery set up manual,
Dec 12, 2008 | Canon imageRUNNER C3200 Copier
Canon imagerunner Ir c3200 total reset
Ok. Press the additional functions key - that is they key with the star inside it - then select 'system settings' then 'network settings' then select 'ip setting'. Once you've got into the ip settings you can enter all your own network settings. All you need to enter is IP address, subnet mask and default gateway but you'll know all that.
Nov 12, 2008 | Canon imageRUNNER C3200 Color Printer
C3200 Network Configuration
Is there a Fiery print controller on the lower rear of the machine? It is a small 10" x 12" box attached to the lower rear cover the network cable plugs into.
Aug 29, 2008 | Canon imageRUNNER C3200 Copier
Configure network card
i am a copier guy and was the first to train on the 3200 series network included this is not a copier problem
Aug 12, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
762 people viewed this question
old marine
old marine
