I took the ball out and cleaned the rollers inside, but it still won't go left...Would I be able to use my HP mouse in the sony vaio computer? or would you have any ides on how to fix my sony mouse?
  • 903 Answers
Most mice are connected via a generic driver, unless you have specific software for it. So the HP mouse should be fine.
Posted on Dec 05, 2008
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
Tip
How to Clean Your Mouse
<p><b><span>Roller Ball Type:-</span></b><br /> <p><span>For cleaning your mouse you have to do the following work.</span><br /> <p><span>1. Disconnect the mouse from your computer CPU.<br /> 2. Turn the mouse upside down and twist the roller ball retaining ring in a counter-clockwise direction to remove the ring.<br /> 3. Remove the roller ball from the mouse cavity.<br /> 4. Wash the roller ball with warm soapy water and put it in dry place.<br /> 5. Replace the dry roller ball back into the mouse cavity.<br /> 6. Replace the roller ball retaining ring and twist it clockwise to tighten.</span><br /> <p><b><span> </span></b><br /> <p><b><span>For Laser type Mouse:-</span></b><br /> <p><span>A laser type mouse requires very little care. Internally, there isn't anything required of you. If it should get a little dirty on the outside, just dampen a soft cloth with water and wipe it until it is clean.</span><br />
on Dec 24, 2010 | Computers & Internet
Mouse will not mover cursor but will right and
Does your mouse use a ball for movement?
Look at bottom of mouse. If so you could have a ditty unit. You can turn the ball cover counter clockwise and remove the ball. Clean the ball and the rollers inside the mouse. Replace the mouse ball and cover and retry the mouse.
Jan 28, 2010 | Computers & Internet
Dell Mouse Scroll Ball Wont Work
If it really _has_ a ball, the rollers inside the ball compartment get clogged with gummy matterial & needs to be cleaned thoroughly - also sometimes the dirt & dust need to be blown out as they can cover the light sensors
Mar 25, 2009 | Computers & Internet
Sony vaio mouse won't go left
Computer mouse are inexpensive. And can be found in any office supply store, even Wal-mart.
You can use the HP or any generic 2 button, scroll ,USB or PS2 mouse on this unit.
Your Sony mouse is bad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 05, 2008 | Computers & Internet
Ball still not working
I checked the feature of the mouse. The mouse can be reprogrammed only for left and right handed person. I guess you need to get the mouse replaced as we already tried replacing the battery.
Thanks
Nov 01, 2008 | Computers & Internet
Mouse
You can remove the roller for cleaning by untwisting the locking cap on the bottom of the mouse. Usually you have to clean the shafts that are turned by the ball. There are two, one for left-right, one for up-down, and there is a spring loaded roller. There is a gummy buildup on these that prevents smooth operation. I use a sharp knife to gently scrape it off. If the shafts are still sticky you may have to dissassemble the entire mouse. Hardly worth the effort unless you have some kind of high powered mouse with special features. BUT, this is not a symptom of a new mouse.
If it is new and does not work, you should consider returning it.
Also, consider an optical mouse. They do not have this problem.
Jul 24, 2008 | HP Computers & Internet
Hp rollerball mouse model M8590PLJ
Flip the small rat upside down!
Remove the ball by turning the round plastic ball retainer counter clockwise. Clean the ball with soapy water, rinse it and dry it, and set it aside.
Look inside the mouse, you should see three white nylon or black plastic rollers, scrape any dirt that might be caked on to them, and clean them throughly with some alchool or acetone.
If you have a can of compressed air, point the the nozzle inside the mouse to expell all the dust out, if you have no air, use your mouth, blow hard!
Put the ball back on the mouse, the plastic retainer (turn clockwise to lock in place). and you're all set to go!
May 13, 2008 | Computers & Internet
My mouse isnt working it has a hard time moving to the left it is difficult to placethe pointer where i want it like to open up mail the mouse is connected to the only port available on the tower ps/2 when...
are you using the mouse on a mouse mat because you get this prob if the place you are using the mouse is greasy or dust are you using an infra red mouse or does it have a ball in the bottom if it has a ball in the bottom a rubber one undo the clip holding the ball in tip it up so the ball comes out you should now see three rollers the one at top is up n down and one at side is left and right the third is just to hold the ball against the other two all these rollers should be smooth usually they get a build up of dirt in the middle of each roler scratch this of with your finger do this with comp on and try rubbing the rollers up and down and see if the mouse is moving on the scrren how it should clean all three of these rollers check theball is clean and not greasy if you can move the pointer using you fingers on the rollers then you know the problem is not your mouse so put back together then the only other thing could be wrong is the mouse mat you will need to replace this or clean it properly try using the mouse on a book and see if this is any better if you have infra red mouse you dont need mouse mat and should have no problem if you still have problems post back and i will try again hope this is some help to you ............................................
Nov 15, 2007 | HP Pavilion MX70 17" CRT Monitor
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
