Question about Kenmore Dryers
Kenmore dryer, electric
Dryer takes to long to dry clothes. Replace the thermal temperature control on electric coil and the thermal cut-off that is in place at the top in the metal duct going into the inside of the drum. The coil comes on, then shuts off I think to long before coming back on. Set timer for one hour drying how long should coil stay on and off cycle. Any idea how hot the inside drum should be??, coils glow cherry red, have a heat gun were to take temperature reading ?? Any help appreciated
    Genius:
  • 1,028 Answers
Forget temp ck..first ck air flow at rear of dryer be sure strong air flow present if not remove back ..remove 4 screws holding blower housing to inside wall remove the 2 screws under lint screen on top ..clean blower housing if housing clear ck vent line all the way to end outside for restrictions ..reinstall line to dryer be sure not to crimp or flatten hose when pushing dryer back to wall ...quick ck dry a load with rear vent hose disconnected if cks ok definite vent restriction
Posted on Dec 05, 2008
Our propane kenmore dryer is not igniting. How do you fix it
GOD IS GOOD !!!!
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Oct 04, 2014 | Dryers
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Thermal Fuse
Air Flow and Heat
Warning
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
Kenmore advantage gas dryer
Thermal Fuse
Air Flow and Heat
Warning
Aug 10, 2014 | Kenmore Dryers
Why dose my Kenmore elite dryer come on and then goes right back off and say f2
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
IS IT GAS? IF SO Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
Air Flow and Heat
Warning
Jul 21, 2014 | Kenmore Dryers
Kenmore gas dryer series 500 won't heat
Thermal Fuse
Air Flow and Heat
Warning
Jul 04, 2014 | Kenmore Elite HE4 Electric Dryer
How do i fix my kenmore gas dryer model 87673100, will not heat up
Thermal Fuse
Air Flow and Heat
Warning
Jun 14, 2014 | Kenmore 63942 Dryer
My Kenmore elite gas dryer sometimes starts and sometimes doesnt ?
Thermal Fuse
Air Flow and Heat
Warning
Jun 02, 2014 | Kenmore 74892 Gas Dryer
Gas dryer not produce high heat
Thermal Fuse
Air Flow and Heat
Warning
May 14, 2014 | Kenmore 62802 Electric Dryer
Dryer stops while clothes drying it appears dryer is over heating, because it takes a while before you can start it back
You have correctly identified the problem - your dryer is overheating. This will almost cetainly be caused by your thermostat having failed in the closed (on) position. The thermostat switches power to the heating coil on/off to keep the dryer at a roughly constant temperature.
Your dryer also has a thermal fuse which cuts all power to the dryer when it overheats. The thermal fuse takes 15-30 minutes to reset - this is why you can't restart the dryer for a while.
Basically, you need a new thermostat!
Please rate this solution if you find it helpful. Thanks!
Nov 01, 2010 | Fisher and Paykel DG08 Electric Dryer
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
Dryers Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
