Question about Thermador PC366BS Stainless Steel Gas Cooktop
Ingiter won't stop sparking.
I've just finished cleaning my stove. After putting all the burner caps back on, the igniter on won't stop sparking on one burner. The burner cap is seated (I've lifted & re-set it multiple times). Other 5 burners OK. Is there anything else that will cause this?
  • Anonymous Aug 27, 2008
    I have the same issue. It started with just one burner and now all four go at the same time. I can't make them stop bu eventually after a few minutes they stop. I am concerned about leaving the house because it happens suddenly for no apparent reason.
  • 175 Answers
You might have cracked the electrode if you were scrubbing next to it, otherwise you might try taking a little sandpaper and scuffing off any residue on the top of the igniter and seeing if that does the trick. Good Luck!
Posted on Jun 18, 2007
My Jenn-Air range top will spark but no ignition. Gas does not seem to have enough pressure on that burner
Generally the issue with this is not that you don't have the correct pressure but the Burner top hat that displaces the gas is dirty.
Remove the metal rack to expose the burner itself. Make sure it's not been used recently to prevent a burn. Carefully lift the little burner cap off. This is the piece with all the holes in it the flames come from. They generally just sit on top. You will need a flashlight, know look in the little slits below the cap for cleaning material buildup. A tooth pick or a stiff bristle tooth brush can be used to clean these little slits.
The cleaning products used to clean stove tops tends to leave little trace amounts of surfactants that over time block these little slits and prevent the escaping gas to flow towards the ignitor preventing the burner from lighting.
Once you have this clean replace the top. Put the pan grate back on and try to relight the stove.
I am sure this should fix you issue. If it doesn't please let me know and I can give you some other tips to try.
DR Wilkins
Oct 16, 2013 | Jenn-Air Cooktops
Once burner lights the "clicking" of the ignition
The most posible cause is that the ingiter have been mositure probably from a water leak and have be short the wires of the ingiter. Their is a small chance that it will dry by it self and be normal again. If not you can remove the top and reach for the ingiter, is a plastic box with a lot of wires in and out and with hair dryer you can try to dry it. If it still sparking again then you need to replace the igniter
Jan 30, 2011 | Viking 37 in. VGSU161 Gas Cooktop
The ignightor click does not stop clicking after stove is on front burner is turned on and back burner ignitor clicks the entire time
Jan 13, 2011 | Five Star 48 in. TTN045 Gas Cooktop
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
The ignitor will not stop sparking.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 23, 2010 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Spark ignitors went on stove top
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Mar 19, 2009 | Jenn-Air JGC8536 Gas Cooktop
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Thermador PC366BS Stainless Steel Gas Cooktop Logo
212 people viewed this question
Top Thermador Cooktops Experts
Spencer Field
Spencer Field
Level 1 Expert
Archie Ferrarini
Archie Ferrarini
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
