Question about Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher
Pulsating Noise from Kenmore Quiteguard Dishwasher
New construction home owned since 9/2007 and in the past month our dishwasher has been making a loud pulsating grinding sound during the wash cycle. When I open the door there is no water in the washer. After shutting it the noise stops and I can hear water entering into the machine followed by a short wash cycle before it drains and grinds again. seems to happen two or three times during each wash. Looking for a possible fix before I call out a repair person
3 Suggested Answers
  • 7 Answers
SOURCE: kenmore dishwasher has loud noise during fill.
This isn't a solution but rather a comment, if the problem is happening only during the fill, then it could be the water inlet valve. Perhaps there is a soliniod going in the valve, watch to see if the fill cycle starts to dimminish over time. Does the sound come anytime the washer fills, ie: rinse cycle? if so I would replace the valve, probably 50 dollars would get you a new one and you can do it yourself to save a little more cash. good luck.
Posted on Apr 20, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Posted on Sep 04, 2009
When finished with cycle the dishes are still wet. It is a ultra wash quiteguard 3
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Apr 22, 2011 | Kenmore Dishwashers
Kenmore dishwasher.not working
I decided to buy a new dishwasher! The motor was making a humming noise after the water filled, and there was a burning smell, so I decided to replace the dishwasher!!
Oct 24, 2009 | Kenmore Dishwashers
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Loud clanking noise in dishwasher
Most likely the motor as food caught in the sump would not make a noise you described.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Dishwashers
Noise, Noise, NOISE
Barring an actual cat being inside the dishwasher, I would surmise that the motor bearings are starved for lubricant, which is something that is not normally done. Sounds like its time for a new dishwasher
May 27, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwasher motor crapout
The dishwasher says kenmore but it is made by whirlpool or frigidaire. If the cost of repair exceed 2/3rds of the cost of a new one it would be best to replace it. Whirlpool makes good models. Their line of kitchenaid seem to be the quietest.
Oct 07, 2007 | Dishwashers
Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
