Question about Casio Parts Cash Register PC Desktop
Doesnt fire up after a power failure
Have power at outlet but till dead is there a reset or accessable fuse
thanks bob ryan
  • 2 more comments
  • burnetthotel Dec 08, 2008
    SORRY MEN I HAVE BEEN AWAY WILL TRY TO GET TO THE REGISTER TODAY AS SOON AS I CAN GET A GOOD PHILIPS SCREWDRIVER ,,,WILL GET BACK TO YA POSSIBLY IN THE A.M.
    MANY THANKS
    BOB RYAN
  • burnetthotel Dec 11, 2008
    GOT THE BASE OFF BUT CANT SEE WHAT RELEASES THE REG. FROM THE METAL PLATE TO ACCES THE FUSE AREA
    THANKS
    BOB RYAN
    NA ,,THE KEYBOARD AND PAPER IS MOUNTED ON A FLAT PLATE AND LOOKS LIKE IT IS SEPARATED SOMEHOW BY A SLIDING MECHANISM BUT CANT SEE HOW IT WORKS OR WHAT NEEDS TO BE MOVED ,,
    THANKS BOB RYAN
  • ccdollar Dec 16, 2008
    I have the same problem but its a sharp XE-A201 and 2 of them died at the same time when the power went out.. we have a dollar store and it was costley to go and get 2 more units !
    so ill get started and see if i can get indside it to look for a fuse type thing... I really want to thank you in advance for any help you can give
    ccdollar
  • 340 Answers
Hei there, and welcome tu FixYa,
You have got a very good model Casio cash registry here, and yes, there is a fuse, that most likely is blown.
Unplug, remove the paper roll from the printer, turn it upside down, remove the screws, turn it downside up again, lift of the cover, follow the power cord til the power supply, in and in the area, you’ll find a fuse, - there is your problem.
DO NOT just put silver paper around it, you risk the whole thing will melt down if something like this happens again.
If that vas helpful, vote "FixYa" thank you
/Teis the Wiz
Posted on Dec 05, 2008
  • 3 more comments
  • Teis Thomsen
    Teis Thomsen Dec 05, 2008
    Come to think it over again,
    - you DON'T have to turn it up side down, as all the screws are on the cover top.
    /Teis
  • Teis Thomsen
    When less than a quarter feel the need to vote for the effort some of us at FixYou offer, I think to myself, ”is it worth it”.
    They get help, and do not care to thank you; “thank you” do not cost a dime, so why????
    /Teis
  • Teis Thomsen
    Teis Thomsen Dec 11, 2008
    I need to know if you are Danish?
    /Teis
  • Teis Thomsen
    What metal plate is that?
    The plate surrounding the power supply?
    - if that’s it, you need to remove that, as it is inside the power supply the fuse is situated.
    /Teis
  • Teis Thomsen
    Sorry, Bob, to hear, as I simply don´t know what else to tell you, other than - it IS a fuse, and its situated in the power supply area.
    /Teis
Worked yesterday, but this morning is totally dead - power at the outlet is fine. Is there a master fuse somewhere? Aprox 4 years old. Thanks,Pat.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 18, 2011 | Emerson MW8626W Microwave Oven
Quit working totally. Checked outlet and have power. Is there a fuse in the oven itself? Reset Switch?
Hope this helps.
Jan 07, 2011 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
No power, display is dead. Is there an internal fuse that can be replaced?
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if you unit has power, and things lite. it is more likely you have a control/switch problem,
Their is no fuse to replace
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | GE XL1800 1100 Watts Microwave Oven
I had a fire in the microwave and now it doesn't turn on. Is there a reset button or do I have to go buy a new one? cbierke@gmail.com
It sounds like an internal fuse has blown. Unplug unit and carefully open the top cover to provide access to the A.C. power cord entry point. Hopefully the fuse is located in that area and is the older style 1/2" long glass or ceramic body with metal endcap on each end. ONLY REPLACE WITH A FUSE THAT HAS IDENTICAL ELECTRICAL RATINGS! After replacing the fuse and top cover reconnect the unit to the A.C. outlet and check to see if it is still dead. Still dead = repair shop time.
NOTE: Use a "fused" A.C. outlet strip (usually 6 outlets with circuit breaker) for your "after fuse replaced" testing. This gives you additional protection against accidentally tripping a breaker in your homes electrical panel.
Oct 19, 2010 | Maytag Microwave Ovens
G.E. ADVANTIUM 120 JUST WENT DEAD NO POWER AT ALL.
Bill,
I have the same unit. It just happened to me. DId you find a resolution?
I was using it on the oven mode and it just stopped working. It's completely dead.
Thanks
Bob
Apr 11, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave dead
one of 3 things, for sure the internal fuse is gone, then check for a: bad Hi-Voltage;diode, Hi-Voltage capacitor, or the magnetron tube is defective,none are too hard to change out,but the magnetron is fairly expensive to replace:
Sep 22, 2009 | Microwave Ovens
After power outtage my f/p washer is dead -no lights nothing
Only reset is to unplug it. Are you sure you have power at the outlet? If you have 120V at the outlet the power surge may have blown the controller, not a cheap fix :(
Apr 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
GE MicroWave JES1136WL01 died while defrosting.
Mine has the same problems. After removing top cover, check fuse on power supply board (mine was OK). Then check thermo fuse located to the far left under the top cover( 2 black wires going to it) using a meter. I then jumped this fuse to see if this was the only problem. I hope to find a replacement thermofuse at the local hardware store.
Nov 17, 2008 | Microwave Ovens
Emerson MW 8115SS
Remove screws, remove cover, replace 20A 125v fuse. Should work.
Nov 16, 2007 | Food Mixers
Casio Parts Cash Register PC Desktop Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
