No heat and I'm cold.
I have a Rheem MD: RGDG-10EAMER, S/N DF50302 F4894 9075.
When I move the thermostat for heat the induction blower operates. The igniter false to glow in 25-30 secods, but the circulation fan operates too.
This problem appears intermittent over the last week. I've noticed the two (2) green lights without an amber when all works according to plan. When the aforementioned problem appears the two green light glow and so does the amber light. The amber lights illuminates after the greens do (2-3 sec). The amber light blinks four times, then on the fifth time the blinking become more rapid.
Thanks!!!
Scott
Cold in Georgia!
  • sbo38 Dec 05, 2008
    I see no code reference....only schematic and diagram.
  • sbo38 Dec 06, 2008
    I have replaced the ignitor. The problem induction fan works, the igniter works, and then the gas. Now the problem is the circulation fan will not shut off after reaching desired temp. Also, twice the gas shut off 7 degrees before reaching desired setting on thermostat.
    I shut off power and turned it back on. The circulation fan comes back on. This was after I let the circulation fan run for 10 min before I shut it off as mentioned.
    I can shut off the power for 10-15 min and the circulation fan will not operate again until I set the thermostat.
    I have tried the paperclip. I've used a meter on both thermo-switches. Both have continuity until I open their circuit with a flame-torch and open them as designed. Both close when cooled (1 min approx).
    Thanks for the suggestions!
Check the flame sensor, should be clean, if not steel wool. They snap easy so be easy on it.
Posted on Feb 13, 2016
  • 85 Answers
Do you have the code reference on your furnace door? If so what does it say? The furnace has locked itself out, and we need to determine what in the world it needs..
Posted on Dec 05, 2008
  • Armando Bernal Dec 05, 2008
    ok, If your getting to no ignitor after inducer fan, and pressure switch (little hose from inducer to little round plastic mounted near inducer) then your ingitor has failed, replace it, a dealer, wholesaler, or contractor will sell you the part, they only need the model number. Expect to pay 15 to 45 dollars depending on their markup. If the fan operates in conjunction with inducer before igniting, the furnace has an open circuit. Look for limit switches near the exchangers (generaly they are manual reset switches), if you have continuity they are ok, same with the auxilary limit (locate switches on schematics), it should have continuity. If you don't want to pull out a meter, then turn off power to unit, pull off two wires from each switch on at a time and put a paperclip or conductor between them. Turn on furnace and if you had a failed switch it will bypass the limit, do not leave this bypassed for long, failure to replace could result in fire danger.
  • Armando Bernal Dec 06, 2008
    If you checked all the mentioned, then only two things could be wrong with the furnace, flame sensor, a short, or bad control board. It is normal for the blower to stay on up to 180 seconds, however it is not normal for it to continue running. Check your fan relay and ensure it is not shorted and causing the blower to work abnormaly. To check therm, pull off therm, disconnect wires, and do the same at the furnace, check for shorts. Then put the red and white together or a temporary therm and watch the cycle, ensure your therm is working properly.
2 Suggested Answers
  • 96 Answers
SOURCE: No Heat and I'm Cold
Your preasure switch is closed
Carrier troubleshooting furnace
If the thermostat isn't selected for "FAN" then the relay is stuck. In heat mode the thermostat opens the gas valve and starts the igniter and the induction motor. If the induction fan isn't running, the flame will stop.
Jan 28, 2014 | Office Equipment & Supplies
Replaced Thermostat and now Blower Motor will not run
Sounds like a set up issue on the tstat. You say this is a packaged unit, inside the machine you should find where the tstat wires hook up. Typically red is power yellow is compressor orange is reversing valve white is emergency heat green is blower. Put red and green together, test blower. Then red green and yellow, make sure blower works again. If blower runs both ways it's either the tstat wire or tstat itself. Make sure you are landing wires on dedicated heat pump terminals, make sure in settings you are set up for heat pump with back up electric heat and TSTAT CONTROLS THE FAN. Good Luck. Also if there is a switch on the tstat for gas or electric on the back you want electric.
May 12, 2017 | Heating & Cooling
Rheem rgph 10eamer 8 yrs old ...blower motor wont stop running...i had the a/c on....decided to ck the furnace ...switched to heat...blower still running....no spark from direct spark...
Hi Richard. The switch they are talking about has a small tube coming from the induction blower housing straight to the switch. The best way to test it is to blow and **** on the tube while it is still connected to the switch. You should hear small clicking sounds coming from the switch, if not than it needs to be replaced. Another thing to try is a small wire or paperclip through the small opening where the tube came off. Sometimes this gets clogged and causes the same issue. Other than that, it can be a blocked flue or the inductive blower motor itself is not working properly. Hope this helps and good luck!
Sep 26, 2010 | Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Rheem gas furnace blower unit not working properly
look at circuit board and follow wires that come from fan motor, if this is a standard motor black is high and it will be going to a prong that says cool, red is low and it will go to heat, you will have a yellow and a blue that are "parked" remove red park it were the blue is and put blue on heat, if this is a variable speed motor you will have to set dip switches via your equipment manual
Sep 29, 2009 | Heating & Cooling
Rheem Model# RGDJ-10eamer sometimes lights and sometimes does not
Find the small tube that runs from the inducer blower. Disconnect the hose and see if there is water in it. If so then I suggest remounting the pressure switch that it is attached to a little higher and so that there is no droop in the tube for water to collect. Just shortening the tube will only allaow water in to the pressure switch. The second thing is with the tube disconnected at the inducer take a straightened paper clip and poke it in the orifice on the nipple attached to the inducer. there may be a partial blockage. Let me know what you find.
Feb 27, 2009 | Heating & Cooling
Dec 05, 2008 | Heating & Cooling
I have a rheem rgdg 10eamer diagnostic light blink 3 times any ideas
i have a rdgd-075auer series that I am looking for the manual or blueprint to install the board on it.
Dec 04, 2008 | Water Heaters
Heating & Cooling Logo
415 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
