Question about HP iPAQ H2210 Pocket PC
Broken SD slot
Hi there, when i insert an SD card into the slot, it says that it's in use but the memory isn't woring, i've tried ressetig too, but no luck. By the way it's spring like mechanism when trying to insert a SD card doesn't work. When i compared the slot with that of a Dell Axim x51v pda, i found that the left most pin (that is slightly upper) is rounded down. i know it's strange, but sometime ago i tried to insert some cards with pressure, it may be the reason. i wanted to know that is it possible for me that i repaire it myself, cause there are no autherized agencies around. Thanks in advance
  • Farghelita Oliya Feb 11, 2007
    Hi tomj23,
    thanks for your response, sorry for being late, but i was busy to take a photo from slot. However, non of them were usefull.
    >>If you want to pursue the disassembly process let us know.<<
    yes please, tell me how.
    thanks in advance
  • Farghelita Oliya Feb 14, 2007
    Hi tomj23,
    thanks in advance
  • 624 Answers
Its possible to take it apart and perhaps fix it, however, the real challenge will be not causing more damage than already exists. So the question is do you need the SD slot working bad enough to risk the entire unit? I wouldn?t recommend disassembling a handheld PC unless you have the tools and the experience working with delicate electronics in tight spaces. If you want to pursue the disassembly process let us know.
Posted on Feb 10, 2007
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
My memory card for my d3100 won't format, I've
Dear Madeline Birch,
I suggest, you use the laptop to format your card. The process is as follows.
- Insert the SD card in the SD Card slot available on your laptop. Enter My Computer, and right click on the icon which represents your card. Format it from there as you would do for any other USB data storage.
If you don't have a laptop, or your laptop doesn't have the SD Card slot. Then, you should purchase an SD Card reader. The process mentioned above would be similar.
If all fails. I recommend you to get another card, as the card may have been corrupted.
Hope I was able to sovle your problem.
Regards,
Rebel K
Jan 13, 2013 | Cameras
I cannot insert my Transcend SD 2 GB memory card in the camera. Is there only 1 type of memory card that can be inserted?
Make sure there's nothing in the slot, and you've got the card oriented properly. The i1237 works with SD and SDHC cards. The Transcend 2GB SD card should work fine.
Jul 20, 2011 | Polaroid i1237 Digital Camera
Memory card error
Make sure your camera can take San Disk. It probably takes a certian card or the SD card might be upside down. Some brand and models stay this fault and the problem with the SD is that it does not accept a memory card higher than 1GB. This info isn't in the user guide. Have you tried an external usb card reader?
Pull the card out and re-insert. the most likely problem is the card was not seated properly in the slot.
Keep us updated.
May 28, 2011 | Canon PowerShot SD950 IS Digital Camera
Says Card Error
Keep us updated.
May 17, 2011 | Vivitar ViviCam 5386 Digital Camera
Memory card error when using sd card to download pictures
Hi
Whats the memory size of your SD card? this printer only support 1gb card.
Thanks for using Fixya
May 13, 2009 | HP Photosmart C6100 All-In-One Printer
How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
Jan 10, 2009 | Dell Inspiron 1525 Notebook
Memory Card
Hi Asunten,
I think ur memory card slot have the problem. It is a physical problem n u must contact mobile technician.
And rina_444,
The memory card for NOKIA and sonyericsson are different.
MMC for NOKIA is micro SD card, or mini SD but for sony ericsson, it accepts m2 card.
Send me a feedback and rate my solution too.
SAJAN(sajwhat_2003@yahoo.com/sajwhat@hotmail.com)
May 09, 2008 | Nokia 3250 Cellular Phone
My Pocket PC with a 4Gb Sd
Hi tHEyOs, Well I?ve been poking around and here are the facts I?ve found: -The largest SD memory card HP lists as an accessory is a 2GB card. -The actual specifications sheet states the SD slot supports SD, SDIO and MMC but makes no mention of any size limitation. My suspicion based on my own personal use of HP hand held PCs is that it will probably accommodate your GB SD memory card. In my own personal experience is that the devices list as accessories only those memory cards that were prevalent at the time the PC was released. So even though the HP site only lists 2GB as the largest its only because the larger cards didn?t exist in the marketplace at the time so it really isn?t any kind of indicator. To me the specifications sheet is the ultimate reference and it doesn?t make note of any type of imitation. If you are still apprehensive buy the memory from a mail order house like TigerDirect and tell them you want a 4GB SD module for an HP H2210 PocketPC. If it doesn?t work you can return it for a full credit. If you have any more questions let us know and please don?t forget to rate the posting.
Feb 11, 2007 | HP iPAQ H2210 Pocket PC
HP iPAQ H2210 Pocket PC Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
