My remote control for my Sansui DVD 80gb HDD recorder is lesss than a year old and now will not work, we have tried new batteries many times but to no avail, I would like to know where I can get a new one, as I need to empty my hard disk drive and do not know how without the remote
  • 790 Answers
Hi
Why not try to repair!? maybe you Infrared led defective! or Crystal try to replace a new one!
Thanks!
Posted on Dec 05, 2008
My remote is not being received by the unit. Unit works fine, and remote is emitting IR. Tried syncing remote but nothing, and cant use the unit without the remote.
8 YEARS has exceeded it's life expectancy by 3 years already as they consider 5 years as a life time in the electronics industry
Jul 02, 2015 | Toshiba RD-XS34 DVD Player/HDD Recorder
How to fit new dvd drive in LG RH7796W DVD 250gig recorder? I've had a serviceman tell me that the 250g HDD needs replaced. I do not want to pay $300 I would sooner have a go myself. Thanks
Open up your LG Recorder. You should see the HDD on the left, the DVD drive in the middle and a circuit board on the right..
Now, look at the back of the dvd drive.. you should see a power connector and a standard IDE interface..
Remove both of those connections carefully. Remove the screws in the black bevels on the sides of the drive and slowly pry out the drive by lifting the IDE interface side above the main board and pulling it out while slipping out the black clips on top of the tray side..
Now that it is done, take your new dvd drive.. you may want to remove the faceplate or at least the plate from the tray ..(slide it upwards.. it should slip out ) .. Place it where the old dvd drive used to be.. do the connections and your good to go..
Before closing, Check to see if the drive is functioning. Close up.
I have swapped drives on my LG many times and even upgraded the HDD.. I have used mainly LG and sony drives..
Mine was originally shipped with 80GB some 3 years ago.. I had put in a 160 GB and now will be putting in a 250 GB as the other is already full and i like to keep those old recordings..
May 29, 2010 | LG RH1999H DVD Recorder/HDD Recorder
Remote control power button and record button both dont work
First thing to try is a fresh set of batteries.
If you can operate these buttons on the main dvd then its a problem with the remote.
If the product is new contact the manufacturer with the fault.
The other thing is go into a supermarket/handy store and ask for a remote that will replace the duff one.
Oct 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Need a new remote control
Go to:
remotehound.com
or
sansui.newremotecontrol.com
Dec 31, 2008 | Sansui VRDVD4005 DVD Player/VCR
Pioneer 530H DVD recorder
You said that you have changed the batteries.
While you're checking the batteries, make sure that the contacts for the batteries aren't corroded or bent. You can clean them with a pencil eraser followed by a nail file. If necessary, gently bend them back to their correct position.
Try these too,
  • Go up to the receiver and try changing the channels without using the Remote Control.
  • Refer to the Remote Control setup instructions, and make sure you have the correct codes programmed for your equipment.
  • Make sure nothing is blocking the front of the receiver (e.g., furniture).
  • Make sure you are operating the Remote Control within 20 feet of the receiver.
If all the above doesnt work,
Then
Either the remote or the receptor on the device is not functioning.
1. Use an Infrared Sensor Card to see if the remote is sending a signal.
2. If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
You can visit this site for further support, www.pioneerelectronics.com/PUSA/Support/CarAudioVideo
Hope my info solves your problem,
Thanx for using fixya....
Oct 01, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Panasonic DMR-EH55 DVD Recorder
i have panasonic DMR-eh55 dvd and for the first time when i played that it was in japanies language thus i tried to convert the language in to english through remote control i selected one by one thus suddenly there came a message U302 and now when i play my dvd and as i press remote control it show on dvd screen U302. please how my remote will work again and how can i get the solution so that my remote control works....
Nov 11, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Televison & Video Logo
Top Televison & Video Experts
