Question about Ecoquest Flair Air Purifier
REPAIR ON MY FLAIR
I had my flair sent in for repair and did not get a repair ticket telling me what was wrong with the unit that they fixed. Am I suppose to get a slip telling me what it is they fixed on it? Secondly, I was told my unit was under warranty when I bought it but didn't get a warranty card for it. Can I still get one as I just bought it brand new about 8 months ago? How do I go about doing it?
If I provide my serial number to you techs can you tell me what was done/repaired to my unit? I like to keep my records straight.
Bonnie
  • 368 Answers
Hi Bonni,
If you bought it new from EcoQuest, the record should be available from EQ Customer Service, or from the Dealer you purchased it from. You should have received (and filed) a warranty card. They should be able to verify who sold it by the serial number, and give you warranty information from that.
Since we techs here at FixYa aren't employed by EcoQuest, we don't have access to the serial number records; you will have to contact the EQ Customer Service there as well.
As for the repair, you would have been given an RMA (Returned Merchandise Authorization) number; without this, you may have difficulties with EQ, since this is how repairs and returns are tracked. Did you deal with this personally or through a Dealer? In any event, they should be able to cross-reference it by serial number and date of service.
EcoQuest Customer Service is at 800-989-2299, or at
customerservice@ecoquestintl.net
if you prefer email.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 14, 2009
I have a Flair air puifier but no ozone smell. I replaced the high voltage transformer( it was a 3500 watt instead of a 5000 watt transformer) The red light now flickers but no ozone smell . It has ne
Your ozone generator may have gone bad. It's the small black rectangular looking apparatus located near the bottom of the unit. It usually has a zip tie holding it to the circuit board. You will have to take the Flair out of it's case to see it. Make sure it's unplugged and remove the bolt from the bottom of the unit. You can then slide the framework out of the casing. It's also possible that it's time to replace your Ceramic Ozone Plates. They have a life expectancy of 2 to 4 years. The Flair has two of them that slide into slots in the rear of the unit. You can see them when you remove the washable filter. All items can be purchased on Ebay. DM
Apr 28, 2012 | Ecoquest Flair Air Purifier
My flair unit does not smell of ozone. Why ??
It properly needs the filter and interior cleaned. Especially, if it has run a long time without being cleaned. Or there is nothing in the household air at this time to trip the Ozone producing switch.
Feb 06, 2011 | Ecoquest Flair Air Purifier
No ozone smell can it be repaired or do i need to buy another unit
You can try a couple of simple fix-its before deciding what to do.
The plates (4" white ceramic squares with screen glued to center of each side) must be clean and inserted correctly.
1) Soak the plates in equal parts plain ammonia/water for 5 minutes. Scrub gently with a toothbrush or small veggie brush. Rinse well. Blow dry or air dry. DO NOT use a towel or paper to dry it off. Avoid touching the screen with your fingers. Clean the metal fingers with a cotton swab and alcohol.
2) Insert the plates firmly, making sure they go in on the tracks, and that the contact fingers rest firmly on the screen part.
If you still detect no ozone, it's probably because the transformer is no longer working. Vollara (formerly EcoQuest/Alpine) no longer repairs or sells the Flair. You may be able to find someone (former dealer perhaps) who has parts and repair skills, or else you'll need to find another machine.
Jan 10, 2011 | Ecoquest Flair Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
Flair sparking
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 09, 2009 | Ecoquest Flair Air Purifier
My Flair Ari purifier makes much more noise
Sounds like Motor or bearing is failing.
You could order parts but you will find it less expensive to replace unit. Than trying to repair.
Please rate. Hope this helped. If i can help you further let me know. Good luck!
Mar 09, 2009 | Ecoquest Flair Air Purifier
New house off gassing
You need to be careful of the saturation. It is an electrical apliance and can be a fire hazard if the fumes are too great. But from my experience with my Flair Classic it will diminish the fumes and smell, but will not completely eliminate it. The paint will have to cure. The unit does work wonders on smoke and musty smells though.
Aug 21, 2008 | Ecoquest Flair Air Purifier
Flair system
Fow owners of all these type devices read my profile, in this current economic times, we are taking in home appliances for estimate of repair, see my profile at allexperts.com
We cannot repair a device that cost $29.00 new for five bucks but if you have a device that is worth something and the only option is to pitch it write me and we will see if we can help wbwill@sbcglobal.net
we will estimate and report back for a proceed
Jul 15, 2008 | Ecoquest Flair Air Purifier
Living Air Purifier (Flair Model) Ecoquest
Pull the unit out of the box and flip it upside down. You should see it
Feb 16, 2008 | Ecoquest Flair Air Purifier
My Fan on My Flair purifier is not turning when I turn on the unit. Nervous about poking around in there don't want to break it, any ideas how to fix this? Thanks
To fix it..........there is one screw on the unit on the outside.........really long!.......remove that and the entire unit just slides out of the housing..........
The replacement fan motor can be purchased on ebay....ranging from $21.95 to $32.95...depending on the model Flair that you have...the most common one is the $29.95 replacement...
Really quite simple to remove and replace!!! and well worth it!
Hope this helps.
Feb 02, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
75 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
