Question about Kenmore 74742 Gas Dryer
Kenmore dryer will not come on
I have a Kenmore dryer and I would like to know other than the switch being what will cause it not to come on. The model number is 86950100 and the serial number is mx46406691
    Sergeant:
    Champion:
  • 291 Answers
Make sure your door switch is good / if not the dryer wont start / larry
Posted on Dec 05, 2008
Kenmore Elite Electric Dryer -- Diagnostic for electronic control "Start" touchpad is 09. What does it mean?
i donot know what 9is but i think its the moter switch or moter try switch first
Jul 19, 2013 | Kenmore Dryers
Kenmore dryer wont start tab broken
Yes that is the lever for the door safety switch. It can be fixed easily,
I have repair pictures and home made video on Kenmore dryers HERE
Dec 02, 2012 | Kenmore Dryers
I have a kenmore steam dryer electric model 8044 and the light in the drum doesn't come on when door open?
It sounds like you have a faulty door switch. Switches are typically inexpensive. You can find Kenmore dryer switches at PartSelect.com (you just have to know what you're looking for):
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Dryer&Brand=Kenmore&PartType=Switch
Dec 28, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
After 500 kenmore dryer is done drying the dryer won't shut off
The push-start switch in the dryer is probably bad. The contacts inside the switch get warped over time, causing the dryer to think you pressed Start again after it finishes a cycle. Replacing that switch should solve your problem. You can find the switch online at PartSelect.com if you know take the rear panel off the dryer and see what the switch looks like.
Nov 06, 2010 | Kenmore 500 6952 Dryer
Kenmore Heavy Duty Dryer Won't start
check the switch on the dryers door
It may be loosely on causing this problem or a loose connection in the wiring to it
Jan 24, 2010 | Kenmore 73952 Gas Dryer
Have a kenmore all in one washer dryer that will
firstly check the motor bushes as this can cause this problem.
Jul 15, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer only heats on more-heat setting
Could be heat selection switch is bad, need to test it with a volt ohm meter
Jan 07, 2009 | Kenmore Dryers
My Kenmore dryer turns on as soon as the timer is set .
Two possibilities:
1) Least likely cause. Start button is not opening when released. Don't know how far you wish to go with this but it will require some troubleshooting.
2) Most likely cause. Motor start switch has a set of contacts that close when the dryer starts and this set of contacts "seals" around the push button. If this is the case, a new switch is in order. Switch is normally replaceable without replacing the motor.
Other option is use "as is".
Nov 20, 2008 | Kenmore 62602 Electric Dryer
Kenmore 74742 Gas Dryer Logo
254 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
