Question about Samsung HCL4715W 47" Rear Projection Television
Power just clicks on and off and the red power led remains on
Just before the extended warranty the converance went out and was replaced, now about 6 months later the set will not power up. Just looking for a little direction, I can do some repairs and troubleshooting myself and our local repair shop gave up without a repair schematic but I've located one and have a copy on hand. Thanks.
  • Rory Mcgaughey Feb 14, 2007
    Thanks, I did find that Q473 is shorted, R486 (R468) did check OK, not open. I'll research on how to check the HV block before I order any parts or maybe not, it's only $54.00 for both items...Thank you all so much and I'll keep you posted.
  • Rory Mcgaughey Feb 21, 2007
    Well, no luck, I just installed the new parts, and there's no change at all..... Thanks, Rory.
    Sergeant:
  • 308 Answers
Check for a shorted transistor Q473, and R468 may be open as well (0.47 ohm @ 2 Watt). If it is shorted, try to find a good replacement part as the Samsung Part Aa96-00037a is No Longer Available. Also there is a possibility that the High Voltage block is also bad, if so, replace with Part Aa26-00101a. Good Luck!
Posted on Feb 11, 2007
Here's my problem, I have a belkin n300 extender, ok it worked for about a week or so and one day I lost connection, when I looked it is solid blue, even after I press reset or wps, it stays blue, I don't...
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Mar 07, 2018 | Belkin Computers & Internet
Sony KDS55A2000 Red Blinking Light Issue
first off
For the KDS55A2000, 9 blinks, pause, 9 blinks means "Device error" and the probable cause locations listed are as follows:
1. Temperature sensors
2. Bus decoder ICs (IC2000, 3150, 3200, 8804)
These are starting points for qualified service technicians. There is a service bulletin for this issue, but it is intended for use by qualified service technicians.
I found that it refers to a problem in the "zero crossing detector" circuit on the "G" board. I resourced the part from an electronics warehouse and found out that the "G" board has a known weakness and high failure rate The part cost me $73+$47 fedex shipping
The "G" board may be the only "plug n' play" board in the whole set
Feb 12, 2008 | Sony KDS55A2000 55" HDTV
Blank LCD laptop does turn on
I beleave you may need to press the function key as well as the F-4 key to bring up an external monitor.
Try holding down the Function key and tapping the F-4 key while watching the screen on the external monitor.
Is your unit within warranty, HP offer an extended 1 year on top of your normal 1 year warranty for video and motherboard issues.
Hope this has helped.
Sep 27, 2009 | HP Compaq Presario CQ50-210US Notebook
Solid red LED for power, Solid green LED for wireless
You can try upgrade the firmware of the device first and then reset to factory default.
Jul 12, 2009 | 2wire 2700HG-B Router (2700HGB)
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
3 months ago Led blinks 7 times now Led blinks 6 times
Sorry to hear that. You could fix it with Best Buy or the warranty service repairman recommended by Panasonic.com
I have a client that had used one of the panasonic repairman to fix the same problem that you have about a year ago,the TV is good ever seen.
I am in the A/V installation business, my recommendation(Pioneer Kuro Plasma TV or Sharp LCD.)Very good track records from my clients.
solutiondoct
Nov 03, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Toshiba Satellite M35X-S161 will not start up...lights come on but no power up???
Hi, Toshiba extended the warranty of the M35 till Nov. of this year for this same problem. If you just contact Toshiba support, they'll rplace the board no charge. I've had a few repaired. They only take a few days. Good luck,
Sep 21, 2007 | Toshiba Satellite M35X-S111 Notebook
Samsung HCL4715W 47" Rear Projection Television Logo
71 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
