Question about Navico Lowrance Thst Dfbl Bronze Th 106 79
I need a replacement transducer for a Navico DS 200 Depth Sounder Old one is bad and I am looking for a replacement. I know they are out of business, but I am looking for a similar one that will work with the DS 200 screen I have. Thanks, Dave
  • Jerry7777 Jan 22, 2009
    I have exactly the same problem. Either need a replacement, or at least the spec of the original to allow me to find a suitable alternative. Thanks
  • Anonymous Dec 06, 2017
    A Nasa 150kHz sensor will work - still available I think.
My ds200 has stopped
if i find it only way to replace you can have the removed transducer
cheers colin jewellersbench@talktalk.net
Posted on Dec 09, 2008
..no depth reading. Old transducer cable was
Hi, Check for debree on depth sensor under boat. As you said check for fuse(s) Good luck.
Jun 20, 2011 | Garmin 185 Sounder GPS Receiver
My Garmin 498C will not show the contore of the bottom or give me a depth reading. The GPS works and will show me charts but, not the sounder option though.
You need to check to see if the depth sounder transducer is connected or functioning. It might be turned off, the connectors may be bad or the transducer is bad. I don't have the 498 manual in front of me but I think there is a test function under the setup menu. I'd check my connections (the usual suspect) then run that.
Garmin tech support is pretty good/quick. So don;t be afraid to give them a call.
Aug 29, 2010 | Garmin GPSMAP 498C Sounder GPS Receiver
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
Depth sounder
the transducer has to be in the water or attached to the inside of the hull if fiberglass with no air between the hull and the transducer. It doesn't transmit thru air.
Mar 12, 2009 | Raymarine Boating
Sounder transducer?
I believe like my own Garmin I have a 178 which is the mono version, same transducer though, you alter the frequencey setting in your main reciever set up program.
Sep 11, 2008 | Garmin 200/50khz, 10/40deg, Plastic,...
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Depth Sounder does not display depth
I will see if I can get mine off the hull for testing. Still have found no procedure. Thinking about just replacing the sounder with another unit.
Jul 05, 2008 | Garmin 185 Sounder GPS Receiver
Depth sounder problem
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Jun 18, 2008 | Furuno GP1650DF GPS Receiver
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Navico Lowrance Thst Dfbl Bronze Th 106 79 Logo
949 people viewed this question
Top Navico Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Navico Boating Expert? Answer questions, earn points and help others
