Question about RCA D52W19 52" Rear Projection Television
My rca d52w19 52 inch shoots a 2 inch flame from the back,WTF
When i plug in tv it tries to turn on and then in the back of tv a 2 inch flame shoots out of some kind of plastic peice with a magnet on it the part reads, OREGA,10799630 and 40351A-5,. Conected to that part is two adjustment holes that read,focus,and screen.it also has a red and black wire attached to the part. It looks like the part is attached to some typ of mother board. I purchesed the tv at wallmart about two and ahalf years ago, it worked great until it did the fire thing. the sn# E-323c1118-b, chassis# itc222. P.S. on the top of the magnet their are #,s S5-19-2,. thanx.
  • RCA Master
  • 5,138 Answers
You are talking about the screen/focus block it is bad sometimes they just split open call UED for replacement part 1-800-836-4920 or go to www.ued.com
Posted on Dec 10, 2008
RCA 52 inch fuzzy screen no buttons work no sound cable doesnt work on it just fuzz
First is you removed power by unplugging the surge protector---this may have confused the micro in the set.
Unplug the set itself (with it turned off) for a while and plug it back to see--sounds like this is your problem to me. Usually in this case only the on/off button on the set works.
Mar 27, 2012 | RCA HD52W56 52" Rear Projection HDTV
The tv just blanked out and when you turn it on it goes right back out.
Having Experience with these TV's and hearing your issue it sounds like your having issues with ether your flyback transformer or the G-board.
There is no way I can verify this as I would need to look at the tv. you looking at a $90-100 fix if you where to take it to a local shop.
What you can do is unplug the TV from the wall outlet allow it to set for a min or two and try turning it back on.
If the problem persist you might look into purchasing a newer model TV, Shoot a 27 inch flat panel LCD you looking under $300 bucks if you shop right.
I would say give this to a salvation army or Good will for recycling if your not up to paying $90 to $100 for repairs. Its is what it is. These RCA;s generally have there fly back go out on them.
Good luck with your tv let me know if you got any questions.
Jan 27, 2011 | RCA TruFlat 27F520T 27" TV
Tv will not turn on leave unpluged a few days plug
The DM power supply board,probobally have those dying leakages gases about to be dead parts call capacitors.U have tools and know basic soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,to replaced those dying capacitors belong in the DM power supply board.
Jul 19, 2010 | RCA Televison & Video
Screen Problem
the pincushion circuit is defective.bang the tv and see if the pix is normal,if so there is bad soldering on the main pc board. rca is known for that
Jul 23, 2009 | RCA TruFlat 27F520T 27" TV
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca 52 inch projection tv 1996
yes convergence ics bad or caps shop 200$ do it your self 50 bucks if u dont have a general skill of electricity electronics do not attemt but easy fix un plug tv look in back u should see 2 large black square ic repalce them and caps outpt resistors this should fix ur problem parts nte semiconducters.com or u can seen it of 2 a factory 2 be serviced pts electronics.com 180.00$ good luck shawn
Apr 18, 2009 | RCA P52926 52" Rear Projection Television
RCA 52 inch tv will not come on and has no sound
you need flyback 259296 you can get one at the following link and they provide free online tech support to help you install it. Heres the link.
http://servicemanuals.vstore.ca/
Jul 17, 2008 | RCA D52W19 52" Rear Projection Television
Sparking on my D52GW12
this is called the flyback. if your technicaly inclined yes solder experence a must. this is and rca tv. you possible can find rca replacement parts. Recently i noticed a price reduction of this Board just depends on the exact model number. You will have to replace the Horizontal output transistor which ussally bad when this happen
Dec 27, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
136 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
