Question about HP 12c Calculator
D.MY button is stuck on the screen of my HP 12c
How do I remove it?
Thanks,
  • leon2825 Mar 09, 2009
    D My program is stuck on my screen, how do you cancel or reset the program
  • 4 Answers
Try pressing blue "g" then "5".
Posted on Mar 16, 2009
Why is my HP-12C stuck on begin ?
The calculator is set to handle payments at the beginning of the period instead of at the end. To switch to the end mode, press g END (END is the g-shifted function of the 8 key).
May 18, 2014 | HP 12c Calculator
Letters d.m.y. on display in my HP12C. How do I remove?
To switch from Date-Month-Year to Month-Date-Year, press g [M.DY]
M.DY is the g-shifted function of the 5 key.
Jan 26, 2013 | HP 12c Calculator
Get out of rpn mode on hp 12c
On a 12C Platinum, press f [ALG]
On a non-Platinum you're stuck. It has only the RPN mode.
Jan 15, 2013 | HP 12c Calculator
Removing complex number in HP 12c
The HP 12C doesn't have a complex mode.
If you're seeing a "C" on the display, it means the calculator is set to use compound interest for the odd period. To switch to using simple interest, press STO followed by EEX.
Apr 12, 2012 | HP 12c Calculator
Cpt button 12c calculator
Unlike TI calculators, the HP 12c doesn't have or need a CPT button. It knows whether you've made a numeric entry or not. To calculate N, I, PV, FV, or PMT, simply press the appropriate key without entering a number.
Feb 22, 2012 | HP 12c Calculator
Screen is flashing 0.00
I had the same problem with my HP 11C. The following solution worked for me.
1. Remove the battery cover.
2. With the batteries in place (i.e. DO NO REMOVE THEM), use a small piece of wire (I used a standard staple bent at one end), short the terminals FOR A BRIEF MOMENT between both ends of the set of batteries (the HP-11C has three). This means somehow inserting the staple such that the contacts in the batteries receptacle are shorted.
3. The flashing will stop. Then push the ON button until the calculator turns on. If it does not work the first time, remove the batteries and resinsert them.
4. You may have to repeat this procedure. I had to do it twice before my calculator worked again.
Apr 28, 2009 | HP 12c Calculator
C showing in display, how to fix
Begin - Press the blue "g" button then 8 ("end") to remove begin. Press the blue "g" and 7 ("BEG") to toggle back to having "Begin on display.
Feb 17, 2009 | HP 12c Calculator
Wrong calculation of mortgage payment
Check to see if the word "BEGIN" appears on your screen. If so, you are calculating the payment on an "annuity due" basis, that is, the first payment is made on day one, and each period thereafter, rather than the first payment being due at the end of the first (30 days usually) period. To fix this, press the blue "g" button, and then press the number "8" (notice the word "end" printed on that key in blue ink). This should return you to the normal (first payment due at the end of the period) option.
Jun 30, 2008 | HP 12c Calculator
Cracked 12c display
Have you looked on Ebay, check with office products dealers, most have what is called junkers just for this reason...
Apr 14, 2008 | HP 12c Calculator
Display a decimal point
Turn the calculator off, then press and hold down the .(decimal key) while you press the on button. Doing so again sets the calculator to use the original digit separators in the display
May 10, 2007 | HP 12c Calculator
HP 12c Calculator Logo
1,804 people viewed this question
Seeker5211
Seeker5211
