Question about Dryers
My Admiral Capacity Plus dryer won't come on. Have checked the wall plug and I do have power. No light or anything. I have heard about the thermal fuse. How do I access the thermal fuse
  • 3 more comments
  • Jasonconner1 Dec 05, 2008
    I checked the thermal fuse with the white wires, everything appeared normal. How do you tell if it has gone bad? Or there some other areas I need to look?
    Sort of. I guess I need to give more information. I hope we are on the right track.
    My Admiral Capacity Plus Dryer is model # LNC7764A71. I would appreciate any further help
    Alrighty. That seems to make sense. The fuse your are talking about, is that the thermal fuse? I didn't see any other fuse in there en route to the door switch. My wife said the timer didn't go off at the end of the cycle, rather, it just shut off and won't turn on. Would you guess this is the door switch?
  • Jasonconner1 Dec 10, 2008
    I have replaced the door switch and the timer assembly and the dryer still won't come on. I do not see any fuses anywhere in the wiring other than the thermal fuse. What should I look for now. Just out of curiosity, what is the timer resistor assembly part that plugs onto the timer? Could that be it?
  • 50 Answers
I have looked at all the parts and diagrams of this dryer and have found nothing on a thermal fuse. i would check the connection on the power cord. maybe it came loose.
Posted on Dec 05, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
I beg to differ on the thermal fuse. If it were the thermal fuse, then the unit will have power but will not heat up or stop. A possibility would be lid/door switch. In some versions, there would be even two. Test could be performed with a continuity tester (VOM or DVM)c set to lowest resistance at X1. When the lid/door is open, the switch will read infinity or very very high resistance, when they are close, the switch will read zero ohms. In the absence of a continuity tester, merely jumping the switch(es) temporarily should be enough to verify whether they are faulty or not.
Additional information perhaps could be more detailed if you could post the exact model number.
Should you find this posting informative and points you in the right direction, then pls ACCEPT. If however you decide to REJECT and/or request additional feedback, then further information from Benimur would no longer be viewable.
Good luck and Thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role Dec 05, 2008
    Hi again,
    Appreciate the quick postback. Somewhere inside the dryer, behind a panel or cover would be a wiring diagram. Pls see if you can find it. Should you have access to a voltmeter, the easiest check to follow would be to start from the AC plug, AC cord them to the inside of the unit. But, this is rather made difficult that you would be testing a live set. For safety reasons, perhaps you could perform the alternate, that would be continuity checks.
    I had a look at the schematic/wiring diagram. It would seem that there is a fuse and thereafter the powerline goes to the doorswitch. The other powerline goes directly to the timer assembly.
    If the cylinder light will not lit when the door/lid is open, then it is either the fuse or the doorswitch that is defective.
    Should you need the schematic/wiring diagram, pls click here. If that does not work, pls try http://www.partselect.com/ and input your model number (LNC7764A71) and click on the SEARCH button.
    Your update(s) on any development(s) would be appreciated.
  • Louie  Role
    The only thermal protection that I know of is connected to the heater. More importantly, your last post is very significant "timer didn't go off" as it could also be indicative that the timer might be in question. The fuse (if present) would be near or along the wire going to the door switch.
    Were you able to view the wiring diagram?
  • Louie  Role
    Louie Role Dec 10, 2008
    You are correct, the thermal fuse with terminals F1 & F2 would be the actual fuse. To test with a continuity tester, it should read zero ohms (0). Alternately for test purposes, it could be temporarily shorted/jumped.
    The timer resistor could be a compensator/limiter for the timer motor to continue functioning even if the other devices have switched off and finish its run.
    Genius:
  • 1,028 Answers
Press clips on front corners of top..lift top back rear just left of center is heating just below element connections is a small thermal fuse with white wires with meter ck for continuity if ck open replace it replacement comes with large thermostat with blue paper be sure to change both
Whirpool cabrio does not run or fill
check the power supply to the unit. if no voltage is found on the unit . check the wall outlet.no power at the wall socket ?? check the breaker box for tripped breakers if breaker to the wall outlet is off but good ,leave as is . check for grounds at the unit . if no grounds are present , turn on breaker . if it breaks with the dryer still not plugged in , search for any appliances connected on that line and unplug all. plug in the dryer then start it .if breaker opens , something is wrong with the dryer. call a qualified technician . thanks .
Sep 07, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
How do you replace the thermal fuse on a admiral capacity plus tumble dryer
The thermal fuse is number 5 on this diagram. http://www.appliancepartspros.com/05-heater-parts-for-admiral-aye2200agw.htmlHere is a link to the thermostat kit.
I would replace all of them. If one goes, the rest will follow soon!
Oct 17, 2012 | Dryers
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Door Switch
Wiring
I have a maytag admiral dryer (ade7000ayw) stopped working over tonight? It's plugged in and the outlet has power.
The thermal fuse is what the problem very likely is. It is located on the side of the heater housing on the upper part of the back wall of rear drum support. To check it UNPLUG DRYER,remove the 2 white wires on the right side of where the heat element goes and check the thermal fuse for continuty (zero ohms resistiance) using a meter set to measure ohms of resistiance
Aug 12, 2011 | Dryers
Admiral Capacity Plus LNC8764A71 stopped heating up, Otherswise fine. Cleaned lint out of front and back. What next?
If this is a gas dryer, you might want to check your thermal fuse. If it's not glowing on start up, replcae it.
Feb 06, 2011 | Admiral AAV7000A
Admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
Jan 07, 2010 | Dryers
Does the Admiral Capacity plus have a reset button anywhere on it. My dryer suddenly stopped only a 4-5 yrs old, great condition. The inside light as well has gone out. It was all ar once no warning
the dryer has a main fuse under the top on the back wall,if that is blown nothing will work,also check the breaker box it might of tripped,-mike
Jun 28, 2009 | Dryers
Dryer won't start
Thermal fuse is your most likely suspect LA 1053
Dec 10, 2008 | Dryers
Admiral Capacity Plus Dryer won't start. No light when door open. Plugged in, Circuit Breaker Reset, socket live, (tested). Internal fuse or circuit breaker?
hi yes there is a thermal fuse in the dryer at the back on the air duct a small plastic piece with 2 small blue wires check that also door switch thanks the appliance doc
Sep 22, 2008 | Dryers
Dryers Logo
662 people viewed this question
Top Dryers Experts
