Green patch on crt screen
There is a green patch on the corner of the crt screen. I seem to recall that there is an easy way to fix it but I can't remember what it is
  • elseano Mar 02, 2009
    we have just brought our astro city 29" arcade game home and after setting it up the sides of the screen are green, we've heard you need to put a magnet against it?? fridge magnet work?? HELP I've just spent my life savings on this machine and it's green.
  • 790 Answers
Hi
Green patch is what we call stain in tube, this is easy to fix just got a magnet then touch the screen you see the green is gone.
Thanks!
Posted on Dec 05, 2008
I have a jvc iart television and i had to transport to my apartment now i have green and red colors in each corners.. How do i remove those colors??
hello,
the problem is a colour patches , you can solve this by using a big size magnet like that in an audio speaker to remove the colour patches.
you do this when the television is power on, and gently moving the magnet towards the screen of television.
hope this will help...
May 21, 2010 | JVC AV-27F802 27" TV
There is a green patch in the bottom right corner of the screen.
Magnetic field prob.move the tv all around to get better or help less green color patch.Like move north south,southeast,southwest get less magnetic field interferences.
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Top portion of the screen is some what green. Every thing else is OK
If you have green patching or anyother colour patching on the screen, your TV may need de-gaussing. The problem is caused when a magnetic field comes close to the TV. A simple solution can often be achieved with a fridge magnet, by moving it over the green patch and pulling it away in certain directions may solve the problem. A TV tech will have a de-gaussing coil which can solve the problem in a matter of minutes.
Sep 26, 2009 | Sylvania 6427TE 27" TV
Screen has green corner at first and may changeto pinks and green
It sounds like the De-gauss circuit isnt working. It demagnetizes the TV tube.
It's something only a tech can fix though.
Jan 02, 2009 | Zenith C27V36 27" TV
Crt tv
This sound very simple. You might need to DEGOUES your tv. Try to find a small degouesing coil at a parts store. This will take 2 seconds to fix. Just plug in the coil and wave it in front of the screen, pull it away from the screen, and it is fixed.
Jun 12, 2008 | Televison & Video
KV-36XBR200 Green in lower left corner
The most common cause is, shadowmask inside of the CRT is magnetized. It sounds by your description that the TV's internal degausser for the CRT is not working. This is serviceable by a service tech.
Most of the time the cause of a failed degausser is the thermoresistor. This is a common type of failure.
Another cause that can show the fault you are seeing is if the shadowmask in the CRT is defective. Sometimes the mask is damaged when the set is being moved, and is accidently banged against something. The CRT is sensitive to this type of treatement.
If the mask inside of the CRT is defvective, the only fix is a new CRT.
Jerry G.
Apr 25, 2008 | Sony KV-36XBR450 36" TV
Colour interestingly different!
Change posistor in the degausing circuit.
Dec 22, 2007 | Toshiba 28N33 28" TV
Green tint on screen
Is it a green tint at some areas alone, oris the entire image having a green tint? If it is a color patch at the corner or other areas of the screen, in all likelihood it is a degaussing problem. Color patches happen when the TV is moved from one location to another, or if some magnetic source is placed close to a CTV. Did you put a radio or Tape recorder or Walkie talkie toy or any magnetic source near the TV? if yes, remove it. And the automatic Dregaussing circuits in the TV will resolve the problem in a couple of days. But if there is an overall Green tint on the picture, it signifies a problem in the Video output stages, and there is nothing you can do, but call the technician (unless you know solid state servicing?)
Aug 07, 2007 | GE 27GT619 27" TV
Screen patch
Sometimes lcds will turn a yellow/brown/redish colour if they overheat. normally this will not cause long term damage to the screen but it is not good for it, try letting the monitor cool then using commpressed air to get rid of dust or attach a small fan to see if it helps. This may not fix the problem but should confirm if thats what it is.
Oct 30, 2006 | Samsung 997DF 19" CRT Monitor
Sony kv-32hv600 picture problems
Problem 1. Color patches at lower corners. These are caused by magnetic sources close to the TV. Do you have any Speakers close to the sides of the TV? Are they Magnetically sheilded? No? Move them away from the TV. Problem should then resolve itself in a couple of days. Problem2. Screen Slumping. Most likely a problem with the Pin cushion correction ckts. Get a good technician to have look. cost should not be much. Under 100$ plus Technician fees.
Aug 18, 2006 | Sony FD Trinitron KV-32HV600 32" TV
Televison & Video Logo
324 people viewed this question
Top Televison & Video Experts
