Question about Holmes Products HQH307 Compact Heater
I have the holmes HQH307 and it went out the caution light and the power light is on i unplugged it and hit reset a day later I turned it back on it stayed on about 3min and went back off. what should i do?
  • Anonymous Dec 10, 2008
    curcuit breaker on back pops out every 15 minutes
  • depotnomore Jan 11, 2009
    depotnomore also has the same problem
Facing forward in the heating area at the top, between the elements is a round disc like object, about the diameter of a nickel. That's the thermal circuit breaker. With the power unplugged, try to clean the surface of it with some alcohol on a long cotton swap. Then use a can of compressed air and lightly blow at it with the guster. You'll need a long plastic blow tube to reach it. Make sure it is dry and that you actually forced the air into the breaker behind the disk to clean it out inside too. You can tell because as you blow around the edge it will lift the disk. You'll see.
I hope you can accomplish this and that it works for you. You could take the unit apart. But it is quite difficult to get it back together. As the grill, which you will have to remove, was not really intended for reassembly. Honestly, this is not a serviceable unit and I would not suggest taking it apart unless you have a lot of patience.
That part you are cleaning is not available, neither from the part manufacturer nor Holmes. They want to sell you a new heater. I won't buy anything else from Holmes now. Delonghi is the company I will try next for a heater. I'll see how that goes and if parts are available to service the unit in five years.
Posted on Nov 04, 2009
Red light keeps blinking
Hello, this is Ava with Think Crucial.
It looks like you may need to change your filters. It is advisable to change filters every 3-6 months for optimal use. When replacing your filters, make sure that the unit is turned off and unplugged from the power. Once filters are replaced, turn on your unit then press and hold the filter check indicator button for 3 seconds. The indicator light will blink 3 times and turn off, and reset the filter change timer.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Aug 24, 2014 | Holmes Products Air Purifiers
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Need heating coils for HQH307. Where can I find them?
Unfortunately, you can't. These heaters are only repairable by the factory. If it's more than a few years old, it's best & cheaper to buy a new one.
Jan 19, 2011 | Holmes Products HQH307 Compact Heater
The power went off at my house due to an overload and when the breaker was turned back on, the tv had no power, no green or orange light. I unplugged the power cord and plugged it in later and the tv...
The power supply board is dead,that the board where the power cord plug into it.Take ur tv aparts,replaced the power supply board,ur tv should work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 23, 2010 | Vizio L32 32 in. LCD HDTV
Heater found turned on but not operating. reset button was pushed out. i tied pushing the reet button back in but it would not stay. any ideas?
Sounds like the thermostat or nobstat is burnt up. I have the same prob. The contacts welded together on mine making it unable to turn off and burning up the thermostart. Looking for one but haven't found it.
Feb 20, 2010 | Holmes Products HQH307 Compact Heater
Vizio vx42l hdtv back light
If backlight went out then sound should still work. Are there any indicator lights to show power is coming on anymore? Try unplugging for 30 seconds, hit power button a few times, then plug back in and try to turn on. This drains any capacitors of power to attempt to reset (basically clearing the TV's throat).
Can also try something on a different input. If current input is composite, S-video, or component, try using DVI or HDMI connection as this uses a different board in the TV. If that fixes it, then at least you can try to replace one board instead of entire tv. :)
Apr 06, 2009 | Vizio VX42L 42 in. LCD TV
Reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
Jan 03, 2009 | Holmes Products Halls HLS5000-U Humidifier
IIcant find parts for the holmes heaters. Who carries them?
I have the same problem. I mean it keeps going off prematurely. The heating area is relatively clean and there is no reason for this other than the Thermal Circuit Breaker to be going bad.
I too have fruitlessly tried to find the part. It is made by Klixon and the info about it is as follows: 1NT15L-4165 It is a manual reset bimetal temperature circuit breaker. Mine says L86 L = Limit and 86 I believe represents 86 degrees Celsius which is about 187 degrees F for us Americans.
I found the Klixon people and they told me the part was not available through them; but only through Holmes themselves. So, I of course called Holmes Customer Service.
Turns out that I had a little spat with Holmes' CS Jerky... She informed me that Holmes does not sell parts and that the heaters they build and sell are not serviceable. So, I argued that they are irresponsible with regard to the environment. What, it's supposed to go to a landfill now?
But she insisted that this was so that people didn't start fires with their heaters. And she says that she has two young girls at home and wouldn't want anyone burning down their house and killing their family. So I guess after all that has nothing to do with her keeping her job by Holmes selling me another $79 heater, huh?? lol Yeah right!!! Because the guy at corporate would not want one of their heaters to start a fire. That wouldn't be an acceptable risk to make money. (Sarcasm, in case you missed it)
On another note... It's real unfortunate that you have to take the HQH307 completely apart to clean the heating area so as to not have the heater be a fire hazard. But I'm a risk to my family by taking the thing apart and then removing the two retaining screws out and two wire leads off to replace the malfunctioning part. WTF??? Since I can't get the part I suppose I could just bypass the circuit breaker. I know that's not a good idea.
Well, bottom line is, (can ya take a guess?), that I will not be buying another Holmes Heater EVER!!! Thanks Holmes...
Answer: As far as I know you cannot get the part.
If anyone has a lead on the part please let me know here.
Thanks, LightningMan
Nov 20, 2008 | Holmes Products HQH307 Compact Heater
My DVR-625, wont even turn on.
at the time the hard drive problem came up the receiver would of went into recovery mode this can take a good hour for it to fix and can do nothing until it would finish on its own and take care of. Doing the power reset is just like unpluging the receiver. Try unpluging again for 30 minutes and plug back in again and just wait receiver should come back on its own. Don't hit any buttons. If not will have to send out to dish for repair. 800-333-3474 dish
Nov 22, 2007 | DISH Network DVR-625 DTV Receiver /...
Holmes Products HQH307 Compact Heater Logo
689 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
