Question about Onkyo DX-C390 6-Disc CD Changer
Onkyo cd player c -707chx is jammed and will not open.
  • contreras1 Dec 24, 2008
    I have the same problem with the C707 Chx! Has anyone found a solution?
  • Anonymous Feb 18, 2009
    Same problem
4 Suggested Answers
SOURCE: CD Carousel for the Onkyo Shelf System
There are a lot of bad reviews of this cd-player for this reason. There used to be bad reviews of it on the Onkyo website; now there are'nt any reviews at all. The cd-changer is a lemon, but it doesn't appear that Onkyo has any intentions of providing a permanent fix for its customers. Mine is doing the same thing.
Posted on Feb 17, 2008
SOURCE: Onkyo C-707chx cd tray jammed won't open won't play
I might have a solution. I have I think the same CD player (3 CD changer) and it got stuck too. For my problem it would play only 1 disc, but it would not open, so I couldn't get my CD's out.
To solve, I poked a thin metal stick underneath the CD player door. I think anything that is thin and strong will work, because basically you're just trying to pry it open. (It might be safest to try this when it's unplugged.) Doing that, I was able to get the door open. I removed the CD's. Then I closed the door again. After this it worked fine, so keeping my fingers crossed it's okay now.
Hope it works for someone else out there having the problem.
Posted on Sep 11, 2009
lock123
  • 6831 Answers
SOURCE: The repair shop suggests sending my cd player to
Hey there
Usually there is a lttle hole in the front panel near the eject button. All you need to is insert a pin into the hole and just pull open the trey.
The button in the little hole releases the locking mechanism so the trey can move out freely.
Please rate solution
Best regards
Posted on Sep 15, 2009
C-707chx
The is hot a remote control problem. It will be a cd deck mechanisn problem. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 12, 2013 | Onkyo Televison & Video
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
CD jammed in player. Won't open.
Your going to have to take it apart and manually remove the cd.
To do this remove the top cover.
Make sure the power is off and that it is unpluged when doing so.
Mar 28, 2010 | Onkyo DX-C390 6-Disc CD Changer
Open a jammed cd player
you have to take a screw driver and open it .the push it from the inside
Feb 01, 2010 | Onkyo DX-C390 6-Disc CD Changer
Solve a jammed cd problem
Usually if you remove the cover you can access the area where the CDs are. You may have to remove the cover from the drive also. Let me know how this works out.
hardrocko
Jan 31, 2010 | Onkyo DX-RD511 CD Player
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
The repair shop suggests sending my cd player to the manufacturer. How do I find out where and if possible? Can't get loading tray to open - seems jammed. Model C-707CHX
Hey there
Best regards
Sep 15, 2009 | Onkyo Audio Players & Recorders
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
My cd player (model dx-1800) is jammed. When I push eject I can hear the necanism but tray will not open
Hi djhartness
It will have a faulty load belt to the tray assembly. Not hard to replace if this in an Onkyo DX1800. You need to use a belt the same cross section as the one that has failed. If you need any help sourcing the part, just let me know. cheers
regards
robotek
Jul 13, 2008 | Onkyo Audio Players & Recorders
Oct 11, 2007 | Audio Players & Recorders
Onkyo DX-C390 6-Disc CD Changer Logo
219 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
