Question about VIA Itona CE, Windows CE, C3-1000, 32MB flash, 128MB RAM. Ports: No Parallel por (LC6941) Network Terminal
Ram problem i am using via 1000 mhz. processor with 128 mb of ram. but system shows only 96.0 mb of ram can i increase the usage size of my ram to its total capacity? someone told me that it can be increased through certain changes in BIOS.
    Novelist:
    Champion:
  • 202 Answers
Farookh, Chances are the 32MB difference is for video memory. You may be able to reduce the video memory in settings and give it back to the system. But you should check to see if it does it automatically. Good Luck, Tim
Posted on Feb 10, 2007
Increase graphics from 96 to 128
If you have insralled the correct video driver and you cannot increase the VIDEO RAM then it is not possible to increase the bit color from 96 bit to 126 or 256 bit color.
The only way to have a higher bit color is to install a new graphics card that supports up to 256 bit color (this video card will have large cideo RAM).
Mar 09, 2012 | Intel Desktop Board D865GVHZL Mainboard -...
Does my TOSHIBA SATELLITE 2805-S301 have a way to go wireless?
No wireless on this laptop you would need to use a usb wireless adapter
roduct Details and Features Product MPN MPN
PS280U-ELCLOH Key Features Laptop Type
Mid-Size Laptop Use
Home Use Processor
Pentium III 650 MHz Hard Drive
10 GB Display
14.1 in. TFT Active Matrix Operating System
Microsoft Windows ME Weight
7.3 lb. Processor Processor Manufacturer
Intel Processor Type
Pentium III Processor Speed
650 MHz Motherboard Bus Speed
100 MHz Memory Installed RAM
128 MB Max Supported RAM
384 MB Installed Cache Memory
256 KB Hard Drive Hard Drive Capacity
10 GB CD / DVD CD / DVD Type
DVD-ROM Optical Drive Read Speed
8x (DVD) Other Drives Floppy Drive
3.5" 1.44 MB floppy Display Display Tech
TFT Active Matrix Screen Size
14.1 in. Video Installed Video Memory
8 MB Audio Audio Output Type
Sound card Operating System Operating System
Microsoft Windows ME Platform
PC Technical Features Input Method
Keyboard Networking Networking Type
Integrated Network Card Data Link Protocol
Ethernet • Fast Ethernet Modem Modem Type
Modem Analog Modulation Protocol
ITU V.90 Battery Battery Run Time
2 Hours Battery Technology
Lithium ion Dimensions Width
12.9 in. Depth
10.7 in. Height
1.5 in. Weight
7.3 lb. Warranty Warranty
1 Year Miscellaneous Product ID
20789390 Family Line
Toshiba Satellite
Jun 19, 2011 | Toshiba Computers & Internet
Where is the wireless on TOSHIBA SATELLITE 2805-S301
Hi just go this link below:
http://www.user-guides.co.uk/cddownload/Toshiba-Satellite-2805-S301-Windows-7-Driver-CD-Recovery-Restore-Disk-326243.html
Jun 19, 2011 | Toshiba Satellite 2805-S301 Notebook
Graphics
1) enter bios
2)make changes in shared graphics to 128 mb
3) increase the size of page sys file allocate more ram to page.sys file by going into rt click my computer/properties/ performance/
4 u can change your windows system to 64 bit.
Sep 19, 2009 | Intel D945GCCR Motherboard
Pentium III 500 mhz will support windows XP
Here is Windows Xp requirements:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jul 28, 2009 | Intel Pentium III Xeon , 500Mhz...
Graphic Problem
This might be an issue with not having full rights within the BIOS, you could try to enter the BIOS and press F8 this sometimes reveals 'hidden' features.
Dec 20, 2008 | Intel Motherboard
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
Memory support confusion
Hello gu11ddu,
Here are the specifications concerning your question about your motherboard's RAM.
Memory Type grayquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz Max Supported RAM grayquestion.gif 4 GB
The key factors that are the most important when you select your ram is the MEMORY TYPE DDR SDRAM, 184 PIN DIMMs, and the SUPPORTED RAM SPEEDS 400 MHz and 333MHz. Your motherboard will support memory no more than 4 GB of memory, so yes you could use the 128mb modules, but you must make certain that they are DDR SDRAM types and 184 Pin DIMMs as this is what the manufacturer suggests is compatiable with your specific motherboard. The supported speed is also a suggestion, because this is the max speed that will work at it's optimal level. You can buy some ram modules that are higher, but they will clock down to the max speed allowed by your system. In other words, say for example you went to your local best buy or circuit city and bought the suggested memory type with the proper pin count and DIMM modules but they only had 500 MHz bus speed, then your system would clock the speed down to 400 MHz. With 4 128mb modules you are only going to get 512 mb max memory, because 4 x 128 mb = 512 mb so you will not be using all the available memory capacity that your motherboard can handle. If you wanted to maximize your memory usage you could buy 4 of the 1 GB memory modules or buy 2 of the 2 GB modules to obtain your max capacity. In your case buying 4 128 mb memory modules would not be worth it because you could buy 1 of the 2 GB modules and get better memory usage.
Another important thing to remember is that you should always use the same type of memory modules and never mix and match them with different ones as this could cause system crashes and problems with lots of memory errors. When going to a local store and asking a sales rep for compatible ram they will ask you what is the make and model of your computer and what your processor speed is because your processor speed also determines your bus speed because your ram will not operate above that speed it will simply clock down (if it is rated higher than what your processor speed is), with this information they will look up any compatible ram they may have in stock. Hope this answers your question and if you need further assistance please let me know.
p.s. your motherboard can support up to a pentium 4 class processor, but this may be different than what you have in your system.
If you do not mind, please rate my help as I would greatly appreciate it. Thanks
Sep 19, 2008 | Intel D915GAG Socket 775 Motherboard -...
I am trying to install office suite 2008. I have followed directions, because it would not come up automatically. I can not get it to load. I have windows xp on my computer.
Microsoft Windows XP - Pentium - RAM 128 MB - HD 210 MB
Min Processor Type Intel Pentium - 133 MHz Min RAM Size 64 MB Min Hard Drive Space 250 MB These are the minimum requirements for your system to have if it has to support for installing pc suite...
Aug 25, 2008 | Computers & Internet
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Computers & Internet Logo
65 people viewed this question
Top VIA Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
jason
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
