Question about Sony Handycam DCR-TRV820 Digital-8 Digital Camcorder
Won't power on
I recently moved hadn't used the camera for several months, it wouldn't power up even with the charger connected. Replaced the standby battery as well with no effect.
0 characters
1 Points
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
I have a PV-IQ404 Panasonic Palmcorder that the power pack has been lost from. Can this be replaced?
By power pack do you mean the actual battery or the charger unit that plugs into the wall to charge or power your Palmcorder? Either way, bot are available on Ebay as universal units and you should make sure the charger or battery pack is for or a 6 volt capacity. Many chargers for these Palmcorders are labeled as VHS-C / 8MM, that should work with your camera. Universal battery packs are made reversable, meaning that you can flip the battery to accomodate several other camcorder models. I've replaced my batteries and charger for my Panasonic Palmcorder from Ebay.
Dec 06, 2014 | Energizer Panasonic Pv-iq404a Camcorder...
Camcorder not working without charger plugged in.
hi if you have the charger plugged in the camera the you have power to work it, if you unplug the charger and it dose not work, the I think the battery is not charged fully or it is no good after being left to long, check to see if the battery is charged. I hope this helps you, please let me know.
Mar 30, 2014 | Sony DCR-DVD602E DVD Camcorder
Handycam not holding charge even with new battery.
Sometimes the batteries will build up a memory if they are only used for short periods of time and never used to the point of going completely dead, so possibly getting a new battery online. B&H photo is a pretty good site.
I know some chargers have an output to the cameras battery connector that powers the camera, and if that is plugged into the charger it will not charge the battery simultaneously.
If the camera is working when plugged into the power source it usually turns out to be a battery problem. Sadly the only choice it to buy a new battery.
Feb 29, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
My Canon ZR950 stopped working all of a sudden. Won't power on with battery (charged externally) or AC power cord. Tape holder doesn't even pop up and open. It won't do ANYTHING. It was...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Jul 16, 2011 | Canon VIXIA HV30 DV Camcorder
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
Jun 02, 2011 | Kodak PlaySport HD
A weird problem has appeared over the past month or so. I power off the camera, and if it is picked up or is moved (sometimes even the slightest movement) and it powers on! What's up with that!?! I have...
The only thing I can think to do would be to turn on the camera and access your settings. Probably check under your power settings or something comparable to it and make sure there is no setting turned on that would allow the camera to turn on with motion.
May 03, 2011 | Canon VIXIA HF S10 Camcorder
Testing a video cam battery's ability to charge
The chargers are usually pretty reliable. You could check it with a voltmeter. I've never replaced one that someone hadn;t dropped or damaged. They just keep woring.
Usually it is the battery. If it had less and less usefull life before it stopped then it definitly is the battery then. If it is more than a few years old it would also indicate the battery.
Mar 22, 2010 | Samsung SC-MX20 Flash Media/AVC Camcorder
Sony Handycam DCR-TRV820 Digital-8 Digital Camcorder Logo
24 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
