Question about Hotpoint TDC32 Electric Dryer
I have a Heavy Duty - 5 cycle dryer that is squeeking. We've taken it apart and found that it's not the belt but something towards the back end of the drum. Would there be a gasket of some kind that has gone bad?
  • Hotpoint Master
  • 3,463 Answers
Could be a dry rear drum bearing, if it has a removable rear panel, unscrew it and spray the end of the drum shaft and bearing with Wd40 or similar.
Please rate this solution
Posted on Dec 05, 2008
I have a Whirlpool Duet Dryer that is locked on the heavy duty cycle, I cant switch to another setting, it wont cancel out. I've tried unplugging it for some time to reset it. It is still stuck o
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be replaced.next time send the model number off of the machine
Feb 02, 2018 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Maytag Heavy Duty /supersize capacity/Quiet Series 100/ 10 cycle dryer. It is not so Quiet when it is turned on, It has a very loud squeak for about 5-10 min. Then it quits and does not have A...
my daughter had same problem. maytag used to be build to last but no more. the dryer tub sits on the front lip around the door opening the support breaks and then the tub has no support and ride around rubbing on opening lip squeeking and causes a lot of friction and will either break the belt or a plastic piece on the motor. it broke all the above on my daughters dryer. we just junked it good luck
Sep 10, 2012 | Dryers
My kenmore heavy duty extra large capacity 2 speed motor when drying my clothes squeeks when turning to dry clothes can I spray wd40 to make it stop squeeking and how or what do I oil?
Most likely a wheel bearing on the tub of a front loading washer, or the belt tensioner pulley on a top load washer. Either is not fixed by lubrication but replacement is called for. There are usually 3-4 wheels on front loaders that could be out. Replace all of them if you are going to replace one. The belt tensioner is a single assembly that can be ordered from any appliance parts warehouse or Sears.
Aug 01, 2012 | Kenmore Washing Machines
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
Dryer is squeeking and does not tumble on heavy loads
It sounds like the belt is gone....
Also check out this tip about your problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Mar 28, 2010 | Frigidaire Dryers
Squeeking while dryer is drying
i would suggest calling the repiar. The longer you wait the more expensive this will be. One of two things is happening. One, bearing is going out, or most likely the belt is slipping on the drum and needs replacement. Good luck
Jul 09, 2009 | Dryers
General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Mar 12, 2009 | Dryers
GE 5 cycle automatic heavy duty dryer
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
Aug 21, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Hotpoint TDC32 Electric Dryer Logo
265 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
