Question about Brother IntelliFAX 4100 Laser Fax
We have a Brother Intellifax4100 When we get faxes, they are clear When we copy, we get a bar on the right side of the page It's about 1.5" thick and consists of a series of streaks Thanks
  • 318 Answers
Try to clean your scanner glass,it might be dirty.Open the dockfeeder area you will find the scanner glass there.Clean with spiritus and cloth.
Posted on Dec 05, 2008
White lines on both faxes and copies
clean the scanner, which is the .5 inch thick piece of glass that the ppr runs over as is is scanned
Nov 19, 2013 | Brother IntelliFax-2820 Laser Fax
Right hand side of page has 1-1/2 inch horizontal streaks down the side
The scanning bar has 28 leds on it and on my 4100 the 6 leds on the right side were flashing on and off,it could be abad connection on that part of the scanning bar caused by a jamed paper.
to tell if your machine is a printing problem or a scanning problem print out the help menu {press the reports key then the 1 key} if it prints clear then every thing with the print cartrige is ok and the problem is in the scanning part of the machine.
Jan 04, 2011 | Brother IntelliFAX 4100 Laser Fax
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax machine won't answer and pickup. I have to manually pick up the receiver and press start. This just started a few days ago.
You probably have it in the fax/tel or TAD mode. Press the butoon on the top right side of the keyboard marked "mode" until the light above it is on "fax" only. This mode (fax/tel) is for phones/faxes hooked to an answering machine. The "fax" mode puts in into the direct answer mode as a fax machine.
May 22, 2009 | Brother IntelliFAX 4100 Laser Fax
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
BLACK LINE 1" THICK ON FAX COPY BEING SENT OUT
I bet your incoming pages are clean right? The Laser is not used for outgoing faxes.
Lift up your document feeder and clean the scanner glass that the documents are scanned across
Feb 24, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Faxing is clean, streaks occur when copying
Open the document feeder cover. The scanner glass is dirty or you have a bad scanner block.
Dec 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
48 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
