Question about Presto 04821 Orville Redenbacher's Popcorn Maker
Not popping the corn
The machine is just throwing the kenerals out of the chamber, unpopped. What should I do?
  • 944 Answers
Here is the link to the user manual for your machine; http://www.gopresto.com/downloads/instructions/04821.pdf If the kernels are not popping, then the heating element that heats the air is likely faulty and would need replacing - Check page 4 of the manual for service info Hope this helps :)
Posted on Apr 20, 2007
Nostalgia Popcorn Maker CCP399 - when the popcorn is popped, unpopped kernels come out with the popped kernels. How can I stop this from happening? Thanks!
You cannot. All poppers of that style will a some "fall out". The better commercial machines have very little as the kettles are deeper, but you cannot eliminate it. The unpopped kernels are not reusable.
Oct 24, 2013 | Nostalgia Electrics CCP399 Vintage...
How do you make popcorn in the poppery ll hot air popper? i do not have owners manual
Hi pdfive...
Put one cup of unpopped corn into the machine, turn on and it will auto eject the popped corn into a waiting pan.
Please take time to rate me
Aug 28, 2011 | Vacuums
What should my powerlevel be on on my microwave because it keeps burning my popcorn
Your power level should be on high, but you shouldn't rely on the oven to time the cooking. I have yet to find an oven that won't burn popcorn if it has a preset POPCORN button. Press it and walk away and next thing you know, you've got charcoal. You should always stick around while making popcorn. Stop the oven and take the bag out when the time between pops drops to 1 or 2 seconds. The corn will continue to pop on its own for a bit because of stored heat, but you won't burn it. You'll never get 100% of the corn to pop, so don't worry about unpopped kernels.
Feb 28, 2011 | Emerson MW8777W Microwave Oven
I purchased the stir crazy model 82306 and it does not pop the corn properly. Less than half of it pops. I have never had this problem with other West Bend stir crazy poppers in the past. On 4 separate...
I have one of these poppers and have been impressed with the minimal number of unpopped kernels.
On only one occassion have I not been satisfied and suspect it was due to insufficient oil being added.
Make sure you are adding sufficient oil to aid heat transfer to the kernels.
Jan 16, 2011 | West Bend 82306 Stir Crazy® Popcorn...
I have a presto hot air corn popper and can't remember how to use it, particularly hot much corn to put into the popper. The model number is 01/pni. Could you please help me as soon as possible, as I...
Does your popper have a butter melting cup at the top? (The one we had years ago did.) Remove that cup from the popper and fill it with the unpopped kernels. (Fill loosely to level with the rim of the cup or less. Do not pack the kernels into the cup or overfill.) Then pour the kernels into the poppiing chamber. There should also be a fill line inside the popping chamber that indicates the maximum amount of popcorn to put in the chamber. Then put the measuring cup/butter melter back on the top of the popper.
The manual for the current Presto Hot Air Popper is available as a PDF from the Presto site. The list of all their popcorn makers is here: http://www.gopresto.com/products/products_search.php?search_value=37&operation=Search&search_type=category . To find the manual click on the hot air popper and scroll down, the user's guide is listed under the parts/accessories available for sale. The current one looks identical to the one that my family had ~20 years ago.
I hope this helps.
Dec 21, 2010 | Presto Kitchen Appliances - Others
Lost the instructions for a nordic ware microwave corn popper
1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
Jun 27, 2010 | Kitchen Appliances - Others
Half the Kernals spit out uncooked
It coud be 2 things. Either a low grade of popping corn, or old popping corn. Hot air poppers blow the same temperature, until you shut them off. Although the better grades of popping corn cost a good amount more, you don't throw half of it away. Once the popping corn container has been opened, you should use it up within about 3 months. The internal moisture content is what determines whether corn will pop or not. Too much or too little moisture will not allow the corn to pop.
Aug 23, 2009 | Toastess Hot-Air Corn Popper Popcorn Maker
Ccp-510 popcorn popper pops only small amount and quits
I had the same problem when I firs bought mine. I followed the instructions as to the proportion of corn to oil. Forget the book! I found that with this machine I had to use three times the oil that was caled for in the instructions to get all of the corn to pop. Better yet, we started purchasing the premade kits with the oil, popcorn and salt. Since changing to both of these systems we have enjoyed GREAT ppcorn!
Feb 01, 2009 | Nostalgia Electrics Helman Group CCP-510...
Directions for presto carmel cormer model #0500001
I have the directions for this; send me your address and I'll mail you a copy or I could probably just I have a Presto Caramel Corn'r. These are the directions:
You need a large mixing spoon, wax paper and the following ingredients:
2 T cooking oil
¼ c popcorn
¼ c butter or margarine
½ c brown sugar
2 T light corn syrup
¼ t salt
1/8 t soda
Then follow these steps
1) Pour cooking oil and popcorn into the unit base. Place cover on base. Plug cord into base and then into wall outlet. The signal light will glow when unit is heating. When popping is completed, the signal light will go out indicating that the heat has shut off automatically. Unplug the cord from the wall outlet. Tip unit upside down so popped corn falls into cover. Set cover with popped corn aside. You may want to use a paper towel to remove excess oil and unpopped corn or hulls from the base before making caramel sauce. NOTE: I pop corn for all the batches I intend to make first then do the next steps because you don’t have to clean it each time to make a new batch.
2) To make caramel sauce, combine butter, brown sugar, corn syrup and salt in the base. Plug into wall outlet. Heat mixture stirring constantly until butter is melted and sugar is dissolved. Continue cooking, stirring occasionally for three minutes. Unplug cord from outlet and unit.
3) Place the mixing band on the base. Add baking soda and stir until mixture is evenly colored, light and foamy. Add popped corn, stirring to evenly coat with caramel sauce. Remove mixing band. Pour caramel coated corn onto wax paper and separate kernels. Let stand a few minutes before serving. Wash unit before popping more corn.
Aug 04, 2008 | Kitchen Appliances - Others
Heating element
What size kettle?
It is probably the thermostat
Oct 31, 2007 | Gold Medal 2086 Popcorn Maker
Presto 04821 Orville Redenbacher's Popcorn Maker Logo
243 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
