Question about Logitech Cordless Mouse
My VX revolution stopped working.
I dropped it on a relativily soft floor (about 2 feet) and it while it showed no outward damage, it stopped working.  I changed the battery and double checked to be sure it was put in the right way but it's still not working.   Is it worth fixing?  I did buy another today but it's not the same model (V220) because that is what they had.
    Sergeant:
  • 302 Answers
Buy another
Posted on Dec 05, 2008
What is the correct positioning of head lamps for a dodge 3500 van 2000?
Headlights should point straight ahead, single sided headlights should drop 2 feet over 100 feet. Dual sided lights drop 1 foot in 100 feet.
Sep 12, 2014 | Cars & Trucks
Hi guys my Toshiba m35x s149 fell 2 feet to a wooden floor.The battery meter shows power of 63% but upon removing the power cord it switches it off.Tried another battery same response.when all is off( no...
I would think that the internal battery connections have been damaged from the fall. They may only need re-soldering. Any drop on to a hard surface from almost any height can damage your laptop.
Apr 18, 2011 | Toshiba Satellite M35X-S149 Notebook
I accidentally kicked my 1tb buffalo external hard disk and it fell the usb connection has been remove and when i connect it again the hard disk start to beep and the computer doesnt recognize and detect...
First try a different usb cable. The cable or the cable connectors may have been damaged as a result of the fall.
If that doesn't work and you are certain that your PC does not recognize the drive, then It appears to me that the fall damaged the delicate mechanical devices inside the drive and you will have to replace it.
Hard drives cannot withstand rough handling. If a hard drive is only dropped about 1 or 2 feet and it lands on a soft surface such as a carpet it MAY survive the fall. But if one falls from a higher elevation, (say 6 feet) onto a hard surfaced floor, it's almost a sure bet that the drive's internal mechanisms are permanently damaged.
To find out for sure, take it to a PC technician and have it tested. It should only cost you a few dollars.
If you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 09, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
HI vx revolution mouse repair
no sorry, once the little pins and rollers inside have broken their isn't any way. I'm really sorry.
Dec 25, 2009 | Logitech VX Revolution 931690-0403 Mouse
Jacques Lemans 5015B model, drop my watch on floor yesterday, 2
You need a hand alignment at the very least. Sounds like your sweep arm is getting stuck on other objects in the face.
Sep 26, 2009 | Jacques Lemans Watches
Wrong Receiver for Logitech Vx Revolution Mouse
logitech has connection software on their site you need to run
Jul 07, 2009 | Logitech VX Revolution 931690-0403 Mouse
Screen will not light up.
Well as crazy as it seems, by dropping it you most likely damaged the backlight for the phone thus making it not light up anymore.
Razr phones are notorious for being damaged easily. There is little you can do but replace it or accept it the way it is.
Sorry for the mishap, and I hope this gives a little clarification on the subject. Thank you for stopping by Fixya.
Mar 17, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Mouse wheel is inverted
if you are using Windows go into conrol panel and click on mouse. it will show you the options to change the buttons..
pls rate this solution
Mar 01, 2009 | Logitech Wireless VX Revolution Laser ...
Mouse doesn't follow
I would venture that for some reason, the LED light at the bottom needs that much space to bounce back the signal for the LDR (light dependent resistor) to read properly. This could be due to a slight misalignment, dust in the bottom optics, weak battery (for wireless). A temporary workaround (which for some works as good enough solution) is to add a smooth spacer atop the rubber feet. Personally, I use a paper puncher to cut little circles on a slightly thick automotive sticker. The circles are then peeled of from the protective paper backing and attached to the existing/original rubber feet. This raises the bottom height which do improve light bounce and therefore mouse action.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 18, 2008 | Logitech VX Revolution 931690-0403 Mouse
Logitech Cordless Mouse Logo
177 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
