The power supply of my pioner dvd was burn
My pioner dvd player DV-C5505 was plug to 220 volts and was blown! it has only 110 volts and accidentally plug into 220 volts. the voltage regulator, transformer was damage! how can i fix this?
  • 790 Answers
Hi
check all semiconductor in the power board and look for a shorted and open parts! then replaced the defective parts.
Thanks!
Posted on Dec 05, 2008
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
My Panasonic S35 DVD player was plugged in to 220 volts instead of 110 volts. The problem is just after replacing two (2) capacitors, diode, and fuse. the unit was accidentally plugged in again to 220...
If the unit is designed to operate at 110V AC, then plugging it into 220V or more without the appropriate multi-current (240-110V) transformer and relative voltage switching circuitry to the PSU (to accommodate the higher current load) is very dangerous. Because of the excess voltage applied, the DVD player's power supply cannot handle this, is basically destroyed, and therefore it would be uneconomical/expensive to repair; although due to the possible extent of the over-voltage damage, I doubt it would be repairable.
To put it bluntly, the whole unit would be a write-off, as the damage to the power supply may have also compromised many of the components on the motherboard. It wouldn't be cost-effective to replace every single part in the circuit. You most likely will need to buy a new player (or find a similar used working one which is not damaged for a cheaper price if that's what you want) and if you do, check to make sure it is a mulit-system/multi-voltage model (can operate between 110V and 240V AC, and is capable of doing so SAFELY) to prevent a disaster like this from happening in the future.
The risks of electrical incidents like this are far too great to even contemplate. One can be lucky sometimes.
Mar 06, 2011 | Panasonic DVD-S35 DVD Player
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
Taking this DVD to Germany, is 220V current OK for the player?
If the label on the charger says something like INPUT=100-240V AC you can use it on all voltages in that range, if the maximum voltage in the label is 220V or higher there is no problem to use it on Germany, if it's 120V or 150V then you need a 220 to 110 volt travel transformer like this one, you can find these travel adapters from about $5 at eBay or at electronics stores. Remember to ask for 220 to 110 (are the same as 230/115) and NOT 110 to 220.
May 11, 2009 | Zenith DVP615 Portable DVD Player
Accindentally pluged it to 220 volts instead of 110 volts
hello , i suggets you replace the power supply with a 110 v input boerd .
or do this if the damage is big replace the all sytem with a new one then get a voltage step down ie 220 to 110.
thank you
May 06, 2009 | Yamaha DVR-S120 DVD Player
BOSE DOESNT TURN ON AFTER PLUGGING TO A 220-240V PLUG AND ITS ONLY 120 VOLTS
It sounds like you hav blown a fuse. Hopefully just a fuse, connecting a 110 to a 240 will hurt.
Most equipment survives short term high voltage but sometimes it just can't take it.
if it's not the fuse then it's very likely damaged the power supply which will require the expert help of a technician..
good luck !
Ps the 321 is a very nice bit of kit..
Mar 30, 2017 | Bose (321GS) System
Blown fuse
usually these step up transformers are design for one appliance at a time , let me know the brand and model number of transformer so I can get the specs info , does the stereo also shuts down?? let me know AJ
May 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Electro Med Services...
