Question about Aspire Digital AD-1100 System
Progressive Scan NOT Interlaced
Hi, I - by mistake pressed Interlace instead of Progressive Scan. I wanted to change settings since one of the DVDs did not work - it just kept reading, but no audio and no video. All DVDs before this worked fine under Progressive Scan. NOthing (DVDs) work now under Interlace! I tried to change it back, but i keep getting a black screen instead of the aspire blue screen. After some time delay, a blue screen does appear - where I can choose settings. Another thing is that the player does NOT recognize the DVDs at first, then it appears as if it's an MP3 where u can select the "folder" you want to play. Tried clicking on the folder - nothing plays! I tried to reset the system - it's still Interlaced - Not Progressive Scan. It doesn't seem to allow me to change it back to Progressive Scan. What am I doing wrong?? Help!! Could you please provide a solution to resolve this issue?
SOURCE: Aspire Digital AD-N820B DVD-R stuck in Progressive Scan ( PSCAN )
I just had the same problem with the same model but I was able to figure it out after a while.
From the remote control:
SETUP
Scroll left or right to the PREFERNCES menu.
Scroll down to the bottom until DEFAULT is highlighted.
HIt the PLAY button in the remote while RESTORE or RESET is highlighted.
The DVD player was reset back to factory settings within 10 seconds.
Posted on Jan 01, 2008
  • 236 Answers
SOURCE: dvd player not showing color
you are only having porblem with your color system. if you are using a multi system DVD player then see if it is properly selected to your region. in USA it should be NTSC 3.59, if you're in Europe it should be PAL. if you're using your DVD via a DSP or audio systems, check also the color system of the amplifier, it should be adjusted to your color system.
Posted on Mar 31, 2008
SOURCE: aspire dvd player model #N820B
The display button is marked OSD (on-screen display).
Posted on Jul 01, 2008
rachelgeek23
  • 155 Answers
SOURCE: ASPIRE DVD Progreesive Scan AD-N8208
Have you tried resetting the power? Unplug the power cord. Hold down the power button for 10seconds. Then try it again.
Posted on Oct 06, 2008
romsky79
  • 822 Answers
SOURCE: DVD player main page is no longer colored (blue)
please enable NTSC. your settings is in PAL. its due to your system PALSECAM.
Posted on Aug 14, 2009
I accidently hit progressive button. Since the screen on my television is now black, I cannot see the menu to change to interlace. What do I do?
Hook your TV up to the yellow composite output, which is usually always interlaced on most DVD players. You should then be able to see the DVD output and can go in and change the component output back to interlaced. Then hook it up normally.
Alternately, you can take your DVD player to a progressive TV, either at a friend's house or even a home theater store to "test" it in progressive mode and then change it back to interlaced.
Nov 30, 2010 | Samsung Televison & Video
Tip
Pioneer DVD-400V DVD Player Interlace Reset
Pioneer DVD-400V Interlace Reset
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and loosing picture, follow these steps:
  1. Switch everything off.
  2. Reconnect using the supplied video cable (standard RCA Red White & Yellow).
  3. Switch the player to standby.
  4. Press and hold the Standy/ON button while pressing the |<< button.
This resets your player to default video output, allowing you to reconfigure your HDMI settings to 1080i, and then reconnect your HDMI cable.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V HDMI Reset
on Jun 06, 2010 | Televison & Video
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Feb 05, 2010 | Sony DAV-FR10W System
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Denon dvd player is in progressive scan-need it in interlace
used single composite video plug to get back to setup.all is good again
Dec 25, 2008 | Denon Televison & Video
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
No progressive scan from component input
Sanyo DS27930 does not support progressive scan
DVD player must be set to interlaced scan
Nov 24, 2007 | Sanyo DS27930 27" TV
How do I reset this ilo dvdr05
To reset to user defaults for mu1 with no video: 1. turn on dvd with no disc 2. press "setup" 3. press "down arrow" 3 times 4. press "enter" 5. press "down arrow" 9 times 6. press "enter" More than likely you changed from interlaced scan to progressive scan. If your tv does not sopport progressive scan there will be no video. The default setting is interlaced scan.
Dec 07, 2006 | iLO DVDR05 DVD Recorder
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Jan 14, 2006 | GPX DV7500 System
Aspire Digital AD-1100 System Logo
35 people viewed this question
Top Aspire Digital Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Aspire Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
