Question about Garmin iQue 3600 GPS Receiver
Garmin iQue 3600. Locked uo and cant turn off, in final steps of upgrading to release 6 with Garmins instructions.
Report abuse posted by ael21012 on Dec 03, 2008 early am
I submitted a question for GPS repair, (first time) on 12/02/08 and again as stated above. This is the 2nd time for describing the problem. I cannot give any more details than the following. I also paid to my account $15.00. I have not recieved a solution or any answer to my problem question, other than to restate the question. How much longer must I wait, which I am willing to do if the time is reasonable.
Arthur Lederle Comment posted on Dec 04, 2008 7:20 pm # 3 posting E-mail ID # 40 from FixYa requested me to resubmit my question. I have a Garmin iQue 3600 GPS/PDA unit that is in a hard 'locked up' stage. Because of a previous problem, (unit went into a 3 screen loop only when it was in GPS map mode, antena unfolded up'). I closed the antena ('fold down') and all other functions worked ok, until I opened the antenna again, to start the GPS. Since this was a 'constant loop', I tried to update the unit's software. I downloaded Release 6 from Garmin along with their instructions on installing the upgrade. All went well until I neared the end of the instructions. I was requested to do a 'soft reset', which I did. The unit would then turn off for a few seconds, then turn on again displaying the 'PalmPowered' screen, which it did. I was then told to follow the instructions on the next screen. Before I could do anything, a screen containing a 'reset' box, and nothing else in it came up. I tried to do the reset by taping the reset button in that screen, but nothing happened. I did a 'soft reset ' again, but the same sequence of screens followed. OF MORE CONCERN TO ME AT THIS TIME, IS THAT I CANNOT TURN THE UNIT OFF.
Must I let the battery run down, or is there a way to get out of the 'hard freeze'? Because of this lockup, I cannot get to any of the PDA functions, making the unit useless. I went tnto a little more detail for this THIRD description of the problem.
Report abuse posted by ael21012 on Dec 03, 2008 Comment posted on Dec 03, 2008 #2 E-mail ID # 40 from FixYa requested me to resubmit my question. I have a Garmin iQue 3600 GPS/PDA unit that is in a hard 'locked up' stage. Because of a previous problem, (unit went into a 3 screen loop only when it was in GPS map mode'). All other functions worked ok, until I opened the antenna to start the GPS. Since this was a 'constant loop', I tried to update the unit's software. I downloaded Release 6 from Garmin along with their instructions on installing the upgrade. All went well until I neared the end of the instructions. I was requested to do a 'soft reset', which I did. The unit would then turn off for a few seconds, then turn on again displaying the 'PalmPowered' screen, which it did. I was then told to follow the instructions on the next screen. Before I could do anything, a screen containing a 'reset' button in it came up. I tried to do the reset by taping the reset button in that screen, but nothing happened. I did a 'soft reset ' again, but the same sequence of screens followed. OF MORE CONCERN TO ME AT THIS TIME, IS THAT I CANNOT TURN THE UNIT OFF.
Must I let the battery run down, or is there a way to get out of the 'hard freeze'? Because of this lockup, I cannot get to any of the PDA functions, making the unit useless. I went tnto a little more detail for this SECOND description of the problem.
Thanks,
Arthur Lederle
  • 1 more comment
  • ael21012 Jun 07, 2009
    get rid of it
    where ia the abuse?
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Hi Arthur,
    Sorry about your issue with your GPS and paying for a solution, which didn't get answered. First, the advice I give is free and I don't pursue paid questions. Second, My expertise is the Garmin Nuvi series. I didn't know what model you had until you answered my question. I am not a participant in the paid expert program.
    I assume that the battery is internal, so you can not disconnect it. Again, I am not familiar with your model. When I hear problems with booting after a firmware upgrade, this is usually an issue of corrupted firmware from a bad flash.
    On the Nuvi series, the power button can be held down and force the unit to attempt to reboot. Is there any possibility that you can try to reconnect it to your PC and attempt to reflash the firmware again?
    Sometimes you get a corrupted flash if the device has not been safely removed before removing the PC to GPS cable. Sometimes the device is still being written to unless you select safely remove it.
    Also, this may not be an issue in your case, but it's always a good idea to have the unit fully charged before attempting to perform a flash of the firmware.
    - Jim
    SHARCNET-USA
5 Suggested Answers
SOURCE: Garmin Ique 3600
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Posted on Apr 30, 2007
SOURCE: Garmin 3600 GPS issue
Same problem here.  It took me a month to find this site and get it resolved.  Thanks everyone.
Posted on Oct 20, 2007
SOURCE: Fritzed Unit when antenna up
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Posted on Jan 25, 2008
SOURCE: Ique 3600 does not work why?
iQue 3600 - mine had the same trouble, but a new external antenna solved the problem. I'm guessing that the "Flip-up Antenna" goes bad after awhile. There are many who use the external antenna. Check Ebay.. buy a new one, not used. Best Wishes, Mark.
Posted on Mar 07, 2009
  • 8 Answers
SOURCE: dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Posted on Mar 21, 2009
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Buy
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
kaufen
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 "Service" manual.
Hello.
You can find the garmin manual here.
Just type in your unit details.
Dec 30, 2008 | Garmin iQue 3600 GPS Receiver
Screen replacement for GarminiQue 3600
I have a 3600 that worked perfectly until i hit the "UPDATER" icon at Garmins suggestion, it fried something but the screen and the rest of the unit are in great shape........ I could not shut the unit off so I took the batter out, the screen is fine, if anyone want it for 40 bucks, drop me a line......... Sammmyg96@aol.com
Nov 04, 2008 | Garmin iQue 3600 GPS Receiver
Garmin wont turn on
IQ-M4 may be different but f it is like the IQ-3600 then press POWER button while pressing RESET then release POWER button.
Aug 08, 2008 | Garmin iQue 3600 GPS Receiver
Repair center for Garmin iQue 3600
dont send your ique 3600 to raytech electr.i leaving at 5 min. from there and last week they tell me they dont repair the ique anymore they send back all there part to garmin they had to much problem with them good lock
May 25, 2008 | Garmin iQue 3600 GPS Receiver
Well unfortunately, sounds like it's replacement time.... same problem I had with mine. Even with an external antenna...no or little signal. Garmin charges $200 canadian for an exchange unit.
So much for costumer support.
Good luck.
Apr 28, 2008 | Garmin iQue 3600 GPS Receiver
Updating R1 on the ique
If you have r1 then you can not upgrade to the latest firmware unless you ugrade to r3 first. Search the internet for r2 and r3 upgrade or call garmin and have them send you a copy of r2 or r3.
Nov 16, 2007 | Garmin iQue 3600 GPS Receiver
Ique 3600 updating from r1 to r6
Call Garmin they are very helpfull.
You may have to go step by step, say from r1 to r3, to r5, to r6.
Garmin USA 1-913-397-8200
Tech support 1-800-800-1020
1-888-442-7646
8am to 5pm Mon -Fri
Garmin Europe 44 1794-519944
Garmin Taiwan 886 2-26429199
Nov 05, 2007 | Garmin iQue 3600 GPS Receiver
I just started having the same problem today too. Go to preferences for gps. I did it by clicking down where the battery symbol is and where the satellite indicator comes up. Then click the quegps in the top left hand corner of the screen. Click preferences and disable WAAS. Seemed to work fine after that. I would like to have WAAS enabled so if you find anything else let me know. Wierd that happened on same day. Let me know s.conley@hotmail.com.
Sep 25, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
270 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
