We have a 31 inch Proton TV. At the top of the screen, you can see where the seal has pulled away fron the screen on the inside. It is drooping a bit on the left side at top, but quiet a bit on the right side. Is there anyway to enter the inside of the TV to reseal this?
    Genius:
  • 2,920 Answers
You would need to take the back off the tv to access the tube,apply adhesive and allow it to set for a few hours.you would have to place it face down on a soft surface for the seal to take hold
Posted on Dec 07, 2008
How to replace chain on chain saw?
you have to loosen your bar nuts. then there is a chain tentioner screw either on the front of the saw or on the side between the bar nuts. turn this screw until the chain is drooping fron bottom of bar. remove the bar nuts, cover, then the bar and chain. make sure the the cutters on the new chain face forward when installed. tighten tensioner screw until chain is snug against bar then replace cover and bar nuts. readjust chain if it is loose. lift unit from handle forcing tip of bar up. this takes away any chance of play in the bar.tighten bar nuts when satisfied that chain is tight. when properly installed you should be able to pull chain upward fron bar and the drive links should not come over the rail guide.
Oct 02, 2014 | Garden
GE 31GT659 31 Picture on right is vertically drooping
Check the degaussing posistor. Replace it. It can be located at the main power regulator section. Will look like this.
Jul 29, 2012 | GE 31GT659 31" TV
Red tint on PROTON TV picture
did u go through the menu and check for the contrast and tints?
Mar 03, 2012 | Proton NT-333 31" TV
MY HITACHI PEROJECTOR TV HAS A DUPLICATE IMAGE IN A DIFFERENT COLOR WHICH DROOPS DOWNWARD AT THE TOP OF THE SCREEN. IT IS 50 INCH
You need to replace your convergence ICs. Please see www.TvRepairKits.com. They have what you are looking for. If you feel you cannot do this repair yourself ask a TV tech. Show him this info, this is your best defense, you now have knowledge for a general repair. Hope you can get repairs at a good price. Thanks for asking and show a few hands of support!
Oct 02, 2010 | Hitachi Televison & Video
Removing and cleaning the screen on a 65" rear projection tv
You can remove the screen, take the speaker cover off in the front you sould be able to see the screws that hold the screen on the bottom remove the screws and unplug the wire the goes to the screen fron the tv, you need two people one on each side just pop each side up about an inch and pull it off,
Jan 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
Protron pltv-32
The only thing would be to have someone take it apart and reset the seals, and re-assemble it, and NEVER buy a Protron again...they are a substandard outfit. Whatever savings you may get up front will not matter when it has problems or dies, because their Cust Serv sucks, to be blunt...cdm62855
Dec 19, 2007 | Protron PLTV-32 Television
LINE ACROSS TOP OF SCREEN-LOOKS LIKE A GASKET
I have the same problem with the gasket dropping from the top of the screen. I took the back casing off (approximately 16 screws) don't forget to take off the adaptor box with two screws. and the additional 8 screws located at the bottom of the panel casing. After that the back panel will come off. Remove the tv screen from the front casing, approximately eight screws. Be careful not to dislodge any wires while remove the screen. Finally remove the gasket. All of this can be done at any local tv repair shop for about $150 dollars.
Dec 02, 2007 | Protron PLTV-32 Television
Rainbow colors after a lightning storm
you need to borrow or rent from a repair shop a degaussing coil. Its a big coil of wire that plugs in and has a switch on it. How you use it? With the coil plugged in,but not switched on ,hold the coil in front center , about two inches fron the picture tube. Now switch on the coil and slowly rotate the coil in a circle all the way around the picture tube and at the same time pulling slowy away fron the front of the picture tube. Keep doing the circular motion till you reach about three feet from the front of the tube, turn the coil sideways fron the tube and quickly shut off the coil. This is done with the tv set on. The set should look clear now ,with no color blotches on the corners or the rest of the picture. If it dosent then the pictre tube is bad. If it does look good, shut off the tv set for a hour or so , turn back on the tv set, Is the colors back on the screen. Yes , then ther thermistor or degaussing circuit needs to be serviced, and this is something you will need to call in a tech to service for you cause theres extremly high voltage inside these sets and not for a handi-person to tinker with. But if its good then your all set. Good Luck
Jun 14, 2006 | Samsung TXN2771HF 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
