Question about GE JVM1650 1000 Watts Microwave Oven
Spacemaker XL1400 I just bought this microwave from a store that sells products that the new homeowners took out but that they can't sell as brand new. I am missing a few screws and I cannot locate any 1/4'-28 x 3 1/4' self aligning machine screws that I need to hold the microwave to my cabinet. I tried Lowes, home deopt and Ace's hardware store. Can anyone help me? I only need 3.
  • gwscant Dec 06, 2008
    I purchased a similar unit, and I have the same problem. It was a floor model and is missing one of the self aligning screws.
    I was going to try getting the same size screw, or even cut one down with a hack saw. I'm not sure what the importance is of the smooth tip, so I'm hoping this approach would work.
I found a solution for my microwave. Went to Ace and picked up some lag bolts, yellow in color (believe they said it was yellow zinc). Most common seems to be 1/4"-20, but these lag bolts had the smaller thread of 1/4"-28.
I had to go a little shorter in length because the threads don't run the entire length of the bolt. The only downside is that the top of the bolt sticks out inside the cabinet (but only about 3/16"). Well worth it so I didn't have to buy an installation kit that was in the $40-$50 range.
Posted on Jan 10, 2009
  • GE Master
  • 9,098 Answers
Sounds like you covered the bases, but I think you;'ll need to order them, possibly in an installation kit.
The installation instructions will give you a list of all the hardware you need.
You can download GE owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 07, 2008
I recently purchased an GE above the oven cooktop oven/microwave and I am concerned with the height of this unit - from the floor. My wife is vertically challenged and I don't want her spill or tilt any of the dishes when removing from the oven.
My question is this - can I simply insert 3' mounting blocks to the bottom of the cabinet shelf and lower the unit? I would replace the existing 1/4" 28" 3 1/4" self aligning screws with longer screws that 6 1/4" in length??? Do they make this type of screw in this size and is this the best way to go??? If so, does any one know where I could purchase them?
Posted on Sep 13, 2010
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Need to find the right kind of brackets to install an over-the-range Spacemaker 1800 Microwave
mcdevito75 here, Shop your area for a Home Depot or other Large Hardware store for these brackets, or you can check with any large store that sells microwave ovens for these bracketts.
Jul 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Door handle broke off. where can i find another door handle for spacemaker XL1400 ?
If its made of plastic, it is better to buy a tube of plastic weld. They are extremly strong, and I have used them time and again. They are available at auto parts store, and hardware stores. They come in two tubes, and you mix them together.
Nov 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker xl1400 microwave quit heating. worked fine, timers, clocks and everything else is fine
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
lkkg
Nov 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker xl1400 microwave quit heating. What do I do?
Cheaper to replace than to repair, buy at lowes or hd for around 300.00 bucks, to repair these things can be upwards of 400 buck, save your time and money, as most appliance techs won't work on them anymore, and go get a new one, unless it two months old then call GE.
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400
Key panel (touch pad) shorted.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1400 microwave doesn't heat anythting
Magnetron may be defective. Replace the magnetron by a new one.
Apr 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
3,088 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
