Question about Electrical Supplies
Sum pump doesnot shut off automatically.frequent on off of sumpump.
  • 3 more comments
  • matt1605 Mar 08, 2009
    My switch gets stuck in the up position causing the pump to stay on for very long periods. How do you change the switch. Is this something you should call a pro to do? Or can I go to a home improvment store and buy it and change it?
  • cvcduty Apr 20, 2009
    I have a pedestal type sump pump and the motor won't shut off... The float is not stuck as it moves the switch arm freely up and down. I had it unplugged for the time being. Can this be repaired? Or, do I need to replace the whole unit? Mine is fairly new... maybe only about two years old. I wonder what the warranty is on these things. I am going to see if I can take it out to see that there is nothing stuck inside that activates the the pump even when there is not water... hmm...
  • Joel Wiedeman May 11, 2010
    Do you have a check valve installed?
  • tom May 11, 2010
    Check to see if the float is stuck.if the float is constantly up it will keep running. some pumps have an adjustable float.
    tom
  • Scott Jelt
    Scott Jelt May 11, 2010
    What type of pump is it? A submersible meaning it is all under water. A pedestal meaning the motor is out of the water usually up a foot or two above the floor.
  • 10,865 Answers
Check the sump hole to see if indeed water coming into the hole is activating the switch and the pump. If that is not the case, your switch may need to be replaced. good luck
Posted on Jan 24, 2009
What is the possible solution u2-23 in sharp ar-m451n
MFP PWB SRAM memory individual data check sumerror.Detail MFPCause
The check sum value for individual data of thecommunication table and the sender registration doesnot match.MFP PWB SRAM trouble.MFP PWB trouble.Strong external noises.
Check & Remedy
Turn OFF/ON the power to initialize the data related tothe content of check sum error.Since the registered contents are deleted, register thedeleted contents again.Use SIM16 to cancel the error.
Replace the MFP PWB.
firmware upgrade it will be good starter..
Dec 17, 2017 | Sharp Office Equipment & Supplies
CODE U2-23 sharp please tell what is the problem ?
Check & Remedy
No Power when power on off
You might have a faulty power supply. Electrolytic capacitors are a frequent failure component. I replaced the caps in two AOC televisions to fix them.
Mar 12, 2014 | AOC L26W898 26" LCD TV
Iam istalling windows xp sp2 on my intel d845gvsr series motherboard computer,but it showing me comdlg32.dll is possibly corrupt header check sum doesnot match the completed check sum. What should I do....
i think there is a virus affected to your bios... did you have any antivirus prog preinstalled... need to flash your bios by downloading the file from other system and putting it tou your floppy... try i hope it will work
Jul 02, 2010 | E-Machines eMachines Desktop PC
Why does startup repair keep popping up on my laptop when i turn it on my sony laptop
This is the system error and it comes when the user doesnot shut the comp in proper way.//
it can also come if due to some reason the comp is shut automatically//
to get rid of it try last known good configuration.
shut down the comp// restart and immed start hitting f 8 cont to get the advance boot menu//
select LKGC and once that is done hopefully your computer will boot perfectly//
May 29, 2010 | Sony VAIO VGN-CS110E/W NoteBook
Nokia n97-a software to press the links
tht happens sum times with nokia n 97..here r few tips
  1. keep ur phone memory free as much as possible
  2. clear ur cache
  3. when using web open ur qwerty keypad nd use the d pad mouse to select link becoz sum times touching doesnot work
  4. also restart ur phone from time to time
  5. last update ur phones firmware latest available is 12.0.024 well 20.sum thin will surely be sumthing great but jst wait for its release
Sep 30, 2009 | Nokia Cell Phones
Computor shuts down. screen goes to black. turn back on and get siren sound and screen says shut down due to thermal event. hit F4 to resume. had same problem a couple years ago and they replaced fan
try applying new cooling pest between cpu heatsink and cpu. Heat from cpu surface should be quickly transferred to heat sink. Either coolent problem or heatsink doesnot properly fit on cpu. But be carefull, you need an 'EXPERT' to do this, or you end up damaging everything.
Jul 30, 2009 | Computers & Internet
My pump does not shut off when the float switch goes down
Good Morning -
I had the same problem with a freind's pump that used a free floating pump switch, first of all the sumpump hole was just barely large enough to accomadate a sump pump, I removed that pump and installed a sumpump that hat a short float connected to the top and bottom of the pump housing and my friend has had no problem.
I did build a short device to make sure the pump as'y stayed in that corner out of 2"pvc.
have a great day!!
TNmec
Dec 24, 2008 | Zoeller Electrical Supplies
Electrical Supplies Logo
320 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
