Question about Plumax PM-350SI-PJS SIlver 3.5" Combo Serial ATA (SATA) / USB 2.0 External Enclosure for SATA or IDE... (DSPMX350SIPJS) Drive Case
Fan vibration I will appreciate if anyone can help me with this. The fan in my drive is vibrating very loudly. How can I fix this? Do I need to replace the fan? I couldn't find a suitable replacement. Are there other options?
    President:
  • 2,961 Answers
Check it's not dust thats causing the imbalance, give it a hoover out, other than this it will be the bearing that's gone and probably not worth replacing.
Posted on Feb 09, 2007
SOURCE:
Vibrating noise when turn on heater/ac fan on 2000 pontiac bonneville
either fan motor is going out ar broken fan wheel, or possibly loose fan motor.
Sep 27, 2012 | 2000 Pontiac Bonneville
Astra G MK4 Radiator Fan working overtime - HELP!!
Probably need to replace the fan. Like anything else they do were out. Just check the mounting points are tight 1st incase its just a loose bolt or clip.
Jul 16, 2012 | Vauxhall Astra Cars & Trucks
How to stop the vibration in my laptop while playing games
There are 3 possible cluprets for vibration in laptops
the fan the cd drive the hard drive
If your issue is coming from the fan assuming it's not damaged often there will be settings to adjust the fan speed as you lower this it will reduce the vibrations.
The cd drive would be your hardest to fix issue if you are using the cd to play the games. better drives do have less movement and possibly a usb connected drive tho bulky could be a solution for you.
A hard drive that vibrates enough to bother is very likely to go bad soon. If this is where the issue is replace as soon as possible. there are now solid state drives that have no vibration.
Sep 14, 2011 | Computers & Internet
Air only works on setting 4 or 5, and is very loud
check fan switch and fan motor as it sounds like the fan is causing the vibration,you need to look under the dash to get more info
Oct 28, 2009 | 2000 Chevrolet Impala
Loud vibration
If it is a frost free check the fan inside. The fans can have bearing failure after a few years thus causing the vibration. Also the compressor underneath is mounted on rubber vibration dampers and if one of these rubber mounts fail then the compressor will start vibrating against the refrigerator frame causing a loud vibration. If none of these apply gently press on the side and front panel of the refrigerator to try and locate the source of the vibration as any where metal is vibrating against metal the side and front panel act as a sounding board amplifying the sound. If you cant locate the vibration then you may have a more serious problem and may need to call a technician.
Oct 09, 2009 | Roper Refrigerators
Blower fan in the freezer is making a vibrating
only if the fan noise is driving you crazy. the noise is probaly the motor starting to go out. you can replace it. it might save you money in the long run to replace it, if it goes out you could run into bad food in your fridge.
Jun 26, 2009 | GE GSS20IEM Side by Side Refrigerator
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Plumax PM-350SI-PJS SIlver 3.5" Combo Serial ATA (SATA) / USB 2.0 External Enclosure for SATA or IDE... (DSPMX350SIPJS) Drive Case Logo
54 people viewed this question
Top Plumax Computers & Internet Experts
Alun Cox
k24674
Are you a Plumax Computer and Internet Expert? Answer questions, earn points and help others
