Question about Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit
Dewalt compressor not filling with air drained tank closed valve
Tanks wont fill up constantly running
    President:
  • Dewalt Master
  • 1,388 Answers
Some dewalt air compressors with single cylinder are known to develop trouble with reed valves and /or failed gaskets in head. Parts lists and parts are available at WWW.toolpartsdirect.com Simple test is to remove air filter and check for suction at intake. Bad reeds will tend to blow air out intake as pressure increases. Failed gaskets in head will cause very high temp at discharge hose. Parts are not too expensive. Enjoy
Posted on Dec 05, 2008
I have a 36 gallon utilitech water tank hooked to a 1/2hp shallow well jet pump my pump runs constantly and I think it's because my tank has no water in it any help would be greatly appreciated
do you have a pressure tank or what, are you doing a gravity type deal with a pump to back it up, all pumps need pressure tank too. or your pump will constantly be on or your tank fill hole is not tight a pump is designed to trip the breaker if it wired direct, if it is not wired direct like wired to an extension cord, then who knows what it will do burn up I imagine if it is constantly going on without water pumping thru it need more details
Nov 17, 2015 | Jet Plumbing
There is a strange noise coming from around my gas tank, a constant running, humming. Just finished filling the tank. When I tried to start the car, it just quits.
i think you might be hearing your electric fuel pump. most likely the noise of the engine muffles it out when running.
Sep 06, 2015 | Cars & Trucks
Almost ran my 99 taurus out of gas . After filling up the car started sputtering and barely made it home where it now wont start. It turns over. Is it my fuel filter now
Unfortunately, you need to locate your fuel rail and use a fuel pressure servce tool to determine if you have a pressure problem. Master fuel o ressure kits have the ability to check fuel pressure before and after fuel filter. When ever you run a tank completely dry it overheats the fuel pump. You should never let your tank get below a 1/4 because the submersed fuel around the pump acts as the pumps cooling system. When a tank is ran lw constantly it kills the kife of the fuel pump.
Jun 10, 2015 | 1999 Ford Taurus
Engine runs rough, no power, stalls
you may need to get your fuel filter replaced
Jan 28, 2014 | 1991 Ford F250
Spray is pulsing
this is usually caused by:
1. water in pressure tank of the compressor - clean the compressor holding tank
2. faulty valve in direct drive compressor (rare!)
3. dirty needle/gasket in the piece.
4. insufficient air flow
regarding 1:
stop the compressor,
open drain on separator and let all liquid out
allow pressure to drop to atmospheric
open drain valve on the tank and drain the content
on the compressor body find oil drain and drain oil
fill with new oil according to instruction on your compressor
close drain valve on the tank and separator
start compressor and check if problem is solved
re 2:
return valve is too difficult to change without specific model knowledge
re 3:
fill 1/3 (pint/500ml or less container)gun container with paint stripper and spray it directly to the sink or other container on full blast - WEAR SAFETY MASK, GOGGLES AND GLOVES! STRIPPER WILL BURN YOUR SKIN!
fill same level with water or solvent and run again, this operation should remove most of residual paints in nozzles and pipes.
check now nozzle for cleanliness and needle assembly, clean what necessary, use bit of vaseline when you will put it back together.
check for consistency of spray on piece of butcher paper with your usual paint. if problem solved - you are fine!
re4;
increase air flow... this actually should be done first.
for better instruction - please provide with model of the gun and paint used.
your comment and rating will be appreciated.
Oct 15, 2013 | Air Tools & Compressors
Fuel spill back up from gas tank when filling tank
Most likely your fuel vent canister is not working and not venting the gas tank when you fill up causing the backsplash or constant clicking off of the nozzle when you try to fill up.
Aug 20, 2013 | Cafe Press No Problem 4 Mom Army Daughte...
Stanley Bostitch compressor cpack model runs and runs but won't fill tank.
check for any air leaks and fix as needed. then look for oil coming from cylinder heads , if oil is coming from heads you have blown head gaskets ,it wont build pressure like this. you might also check the pop off valve to be blown open. push the pin in and see if air starts to build up then. If so get a new valve.also check the drain valve under the tank and make sure its closed.
Apr 17, 2013 | Air Tools & Compressors
Tank isn't filling with air
Is the drain valve on bottom of tank closed? Is the regulator turned all the way out?
If those are set where they should be, one or both read valves may be damadaged, these are on top of the piston(s). It is also possible the piston seals failed or are missing. It is also possible the check ball is missing or damaged. This would be in the cylinder head opposite the side piped to the tank.
Feb 02, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Hey there. I am having problems with my Emglo Dewalt d55151 compressor. I have taken it apart and and cleaned everything up. The reason I did all this was..because the cold start valve stays open and its...
The cold start valve will close when volume of air from compressor is sufficient to overcome spring under pin (allows the motor to come up to speed). Evidently your compressor is producing very little air. Usually the problem is leaking or broken reed valves or gaskets. Remove the head and look for torn/ leaking gaskets and replace as needed. Examing the reed valves and seats and look for broken cracked reeds or worn seats. Some of the valve plates used in Dewalt compressors are made of aluminum and would fail. Parts are available at www.toolpartsdirect.com or local dewalt service center. Good luck with your repair.
Apr 25, 2011 | Dewalt d55151 factory reconditioned emglo...
Taking a shower the pump goes on an off constantly,is it not suppose to fill the tank up first then discharge the water?
Yes it is suppose to fill tank nearly full then pump down and shut off. I would check to make sure that the float switch is not hanging up on something or perhaps rubbing on the tank wall that is stopping the pump from running long enough to empty tank.
Check the placement of pump and float to make sure they are not hitting on anything. Adjust float as needed to allow for max pump down. Also make sure that there is a check valve installed in discharge line so that any discharge can not run back into tank when pump shuts off. Hope this helps you. Thanks
Jan 05, 2011 | Saniflo & Saniplus& Macerator Pump
Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit Logo
445 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
