Question about DEI Python 1400XP Remote Start/Keyless Entry System
Python 1400XP remote start system
This was installed a 2003 Chevrolet Monte Carlo, it was working ok. the car had a problem the body control module and the system was disconnected. Went to have the system hooked back up and the place where it was installed had closed. I hooked everything back up, the remote door locks work ok and the remote trunk release work ok but the remote start does not. when you activate the remote start, it powers up, you hear the relays click and the lights come on but it does not crank or start the engine. It cycles off and on several times doing the same thing then shuts off. the engine starts fine with the key and the engine will stay running when the remote start is activated when the engine is running and when you shut it off and take the key out. Is there a relearn procedure or reset procedure that needs to be done? I only have the owners manual information. I do not have any installation instructions. Any help would be appreciated.
  • Anonymous Mar 23, 2014
    i reset python 1400xp remote start/keyless entry. does not operate door locks, only left front and right rear locks will operate manually
  • 34 Answers
Yes you are correct the learn procedure is done by a dei 555L or a 555G bypass module.your car should have one or the other installed on it. simply unplug it,it will be a three wire plug. then plug it back in and then by turning the ignition on and off it will relearn the code.
Posted on Jan 09, 2009
  • jaker_02 Dec 17, 2010
    JRatzlaff - Did this solution work? I am having the same exact trouble down to a "T" that you described above. Car will start fine with key, remains running when remote is removed from ignition, lights, relays and solenoid sound fine when remote is pressed, but never cranks. And will try to start three times. Recenetly had car at dealership and this problem surfaced when I got the car home. And of course the dealership claims there did nothing to cause this and refuse to look at it since it is an aftermarket product.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2003 monte carlo does not start
need to narrow down to electrical or fuel management --when no start is fuel pump working ---has the ignition system been tested or starter when no start
Jul 08, 2017 | 2003 Chevrolet Monte Carlo
Python 1400xp installed by circuit city on a 2004 chevy monte carlo. The car works fine but every now and then the car will not start with the remote or with the key, it takes 10- 30 mins to finally...
check your starter they act up like that, when it will not start if you could try to hit it with a hammer, pipe anything you can not on the solenoid but on the body of the starter if it start up you know that is your problem.
Sep 15, 2017 | DEI Python 1400XP Remote Start/Keyless...
Have a 2003 Monte Carlo SS. Usually happens when I first start the car. The cruise control light comes on in dashboard at the same time the air, heat and defrost won't work. After a few minutes everything...
most of the newer cars especially the new chevys are all ran off the bcm or body control module, i would have someone with a snap-on brand tester check to bcm and the parts of your car first to make sure what is all wrong, could just be a shorted wire or a broken vacuum hose
Jun 26, 2009 | 2003 Chevrolet Monte Carlo
Circuit City installed Python 1400XP on my 2002 Suburban.
That does not sound intierly tru but what is the year ,make and model of your car and i can check for you. but if memory seves me right it just consists of alot of extra work that most tech's dont like to do.
Nov 14, 2008 | DEI Python 1400XP Remote Start/Keyless...
DEI Python 1400XP Remote Start/Keyless Entry System Logo
594 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
