Question about Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit
Dewalt compressor not filling with air
Constantly running
  • David Ford
    David Ford May 11, 2010
    can you be more specific, is it not shutting off or are the petcocks open or do you have a major air leak?
I have a Dewalt 2hp 4 gallon air compressor and it will not pressurize. When I turn it off I can hear and feel air coming out of a little needle valve where the line from the compressor goes into the tank. The pin is very small and down inside the hole - can barely see the tip.
Posted on Apr 25, 2009
  • 21 Answers
If you do not have any air leaks and it is a oil less compressor than it is most likely the piston seal is wore out. if it is an oil compressor that it is likely a flapper valve
Posted on Dec 21, 2008
Paslode
Make sure that you dry the top of the motor housing and connections.Make sure that the piston is up as far as it can go.
When you depress the nose against the work the motor should run and if you look at the flashing light on the side it will stay constantly on and momentarily flash when you pull the trigger. If it goes red then check the battery is charged otherwise there coiuld be a fault with the motor.
Is the inlet Valve facing the correct way with the bottom of the "V" facing down into the machine.
Check the date of the gas, make sure it is not out of date.
Is the gas cold? warm the cylinder up by putting it in your trouser pocket for 10 min. Paslode make winter gas for these cold days.
Jan 10, 2013 | RTO PasLode 900420 Impulse Framing Nailer
My nailer won't work
Do you have a constant air leak at the head of the gun? If so you have a blown diaphram seal. Order from mfg.
Feb 10, 2012 | Shop Fox W1776 18 Gauge 38"2" Brad Nailer...
A constant air flow coming out by trigger...
if this is a Bostitch you would need to replace the trigger valve, if not give me the correct model and brand and I will see if I can find a breakdown for you. In replacing the trigger I have detailed instructions in the tip section.
Sep 10, 2011 | Bosch Air Tools & Compressors
Unit runs constantly but only reaches 45psi. Compressor doesnt sound the same either. All lines and couplers seem ok.
If you are only getting to 45 psi, you have a problem with either your reed valves or piston rings/cylinder assembly. If you feel comfortable taking it apart, removing the head(s) on the pump will let you inspect both to see which is the problem. The reeds on the valve plate have to be in perfect condition. Buildup, broken or bent reeds will prevent them from sealing so air can be pumped into the tanks. If the seal (oiless) or rings (oil lubricated) around the piston are damaged the same result will occur. These can be indicated by excessive wear marks on the cylinder or stray peices on top of the piston. Both are simple fixes and fairly inexpensive. Without your model number I don't know which parts to recommend. On Ridgid's website they have an excellent parts lookup system and you can order from them or use the part numbers to check other websites for prices.
May 26, 2011 | Ridgid r Factory Reconditioned 325 HP 45...
I have a bostitch 6 gal pancake compressor that won't build pressure past about 20 lbs. when I turn it off I don't hear air leaking out anywhere and when it's running it runs at a higher pitch ( similar to...
I'd pull the cover off to expose top of cylinder head and have a look at any intake air filter. In parts diagram, It appears there is a small one that would likely clog during the texturing process.
Jan 26, 2011 | Stanley Bostitch CAP2060P 105 Amp...
Constant air leak
Sounds like you need a repair kit or take to a tool company that installs the kit.
Jun 09, 2009 | Stanley Bostitch Coil Framing Nailer
Paslode cordless framing nailer model 325 (black)
the fan is what returns the valve in the chamber, whilst it may have been lubed it must be spotless in the chamber. Use paslode gun cleaner a clean cloth and the handle of a wooden spoon or similar and clean all residue and grime out of chamber and re lube. Or you just have a dead tool that was used for parts! good luck
May 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Dewalt compressor not filling with air drained tank closed valve
Some dewalt air compressors with single cylinder are known to develop trouble with reed valves and /or failed gaskets in head. Parts lists and parts are available at WWW.toolpartsdirect.com Simple test is to remove air filter and check for suction at intake. Bad reeds will tend to blow air out intake as pressure increases. Failed gaskets in head will cause very high temp at discharge hose. Parts are not too expensive. Enjoy
Dec 05, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Dewalt compressor not filling with air constantly running
hi your problem seems to lie with the valves in the cylinder head not sealing i suggest you obtain a new valve set and replace said items
hope this helps
Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit Logo
432 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
john h
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
