Question about Canon PowerShot A80 Digital Camera
Canon a80 camera
I have a canon a80 camera which was dropped whilst on holiday and has been sent for repair.this has been returned from authorised repairer and on taking some photos and video there is a horizontal line across the picture which transfers to computer screen. the lcd screen on the camera also shows this line when trying to take a photo..This does not happen with every photo, probably about 10 % of ones taken ...
  • philip warner Feb 24, 2007
    Thanks, as you suggest it was taken there initially as the lense was not jemmed but noisy as if the gears were slipping on it. i have today returned it and explained that it is a fault since the repair and not before. thanks for your advice i will go armed with it when i collect the camera, to haggle over any cost.. thanks again
    Novelist:
  • 107 Answers
It seems that either the image sensor or the connection between the image sensor and the processing board has been damaged or was improperly installed. If you sent it in because the lens was jammed it is highly likely that this is what has happened. See if you can get the facility who repaired it to cover the re-do, in the end it is their fault if your CCD is defective now and was not before the repair. However - if the camera was non functional after you dropped it they could very well say that the impact caused the problem. You might have no options besides either dealing with the issue or replacing the camera. David Millier Advance Camera Repair
Posted on Feb 24, 2007
My Canon powershot a80 will not come on.
It sounds memory card is defective and preventing camera to turn ON.
Check camera with another memory card or try this memory card in another Canon camera to confirm it.
Dec 09, 2009 | Canon PowerShot A80 Digital Camera
Canon PowerShot A80 - no display through the lens
See this link. The symptoms indicate that your CCD (image sensor) failed. Canon will repair this at no charge, regardless of warranty status. Contact them as described at the link.
Nov 16, 2009 | Canon PowerShot A80 Digital Camera
Screen streaky & longditudal flashing across then goes black looking at pictures taken are ok & are clear camara has not been dropped unable to take a pictur now
The sensor array has gone bad. It will bave to be sent back to Canon for service since that is a major repair. You should consider the A480 as a replacement camera. The A480 is a little over $100 and is going to be cheaper than repairing your A95, plus the A480 will have better resolution and picture quality. It will not use you adapter lenses, if you have any.
Nov 12, 2009 | Canon PowerShot A95 Digital Camera
I have a canon A80 AiAF. Sreen Problems
Its known problem of CCD Imager in Canon A80 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Jul 19, 2009 | Canon PowerShot A80 Digital Camera
Canon Power Shot A80 LCD screen not working.
http://www.fixya.com/support/r1237608-canon_powershot_cameras_pink_black
It seems that this is a problem with some of the canon pwershot series.
Please check out the link above regarding the same. It might help before you decide on repairs.
Please rate this solutions and thanks for using FixYa!
Mar 09, 2009 | Canon PowerShot A80 Digital Camera
Vertical lines obscuring image
The matrix is dead. Probably because of an intensive light got into the lense while the camera was in night mode. It's dead. Nothing can be done.
Jul 24, 2008 | Canon PowerShot A80 Digital Camera
LCD screen broken from being dropped - just a black splodge!
Replacement parts for digital cameras are hard to come by. even if you could find one, the electrical connections inside the camera is more problematic. the best suggestion is to take it to a camera shop and see how much the repair cost would be, (probably over $100). if you do not want to invest that in a repair, there are some really good digital cameras out there for about the same price as the repair. If you want to try finding an LCD screen for your camera, try Camera Repair Japan, CRJ, located in Duluth, GA, phone # 770-849-0555. Good luck.
Jan 11, 2008 | Canon PowerShot A80 Digital Camera
Needed a help
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Oct 22, 2007 | Canon PowerShot A95 Digital Camera
Help with code
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 05, 2007 | Canon PowerShot A80 Digital Camera
Canon a80 lcd screen
The LCD screen's connection to the circuit board is not seated properly, or the LCD screen itself is defective. You are correct in that when you touch the screen you are affecting a bad connection. You should take the item back to the place that repaired it, or find another service center if they will not fix the problem for free. This is either a problem with their workmanship or with the LCD they installed.
Feb 22, 2007 | Canon PowerShot A80 Digital Camera
Canon PowerShot A80 Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
