Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Keeps clicking on and off
I have a kenmore 10674942400 top frezzer it keeps clicking off and on until i turn dwn the thermo dwn or turn off for a few minutes then will work fine for few days and starts again. Also i have ice forming inside the frezzer.
  • fsrrii Dec 05, 2008
    I cleaned the compressor and the condensor very good the fan is clean and run good . The ice forming is on the other side of the ice maker on the the back side now .
  • fsrrii Dec 07, 2008
    Thanks for all your help I think the problem is solved . After I clean the fan condenser compresser and removed the ice maker and cleaned all the ice forming from the back . I found the drain was cluged with ice . now it make ice and running fine again thanks.
    Scholar:
  • 82 Answers
Hello.
It sounds like your condenser fan might not be working, and causing your compressor to over heat. When you turn it down, the thermostat isn't demanding as much run time so the compressor isn't on as much, thus not overheating. Take off the back panel near the floor and see if it is turning or not. Also make sure the condenser coils underneath the frig are clean. If not them vacuum them out.
When it comes to the ice issue, you will need to be more specific. Where is the ice forming? And is it ice or frost?
Posted on Dec 05, 2008
  • Shane Hays Dec 05, 2008
    It sounds like your compressor relay might be weak and going out or your compressor is going out and it drawing too many amps, causing the relay to overload and start clicking.
    The ice sounds like you need to make sure the tube that goes from the back wall into the icemaker isn't coming out. Try pushing it back into the wall. Or it may have gone too far into the wall and needs to be pushe forward into the icemaker fill cup.
    Let me know how it goes.
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Fridge not getting cold
if the frezzer is on top in this model and food is frozen it may be the ciculation fan motor.You can advance the defrost timer,located where the control knob is inside the frdge.with a phillips head screwdriver inserted into hole turn defrost timer it should make a clicking sound if this goes all the way around and the fan does not come on it is probablly burned out
Jan 29, 2012 | Kenmore Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My defrost on my Kenmore-Model-596.9535680 is not working -will not keep unit cold and appears that possibly the freezer motor is not working. Any ideas?
if the frezzer motor not working check that it get 120v if it is getting power and not turning the fan need to be change and you can get it at sears parts direct web site...
Dec 29, 2009 | Kenmore Refrigerators
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
Themes for samsung j700
please log on to www.google.com and search for samsung j 700 themes for free.
Feb 17, 2009 | Samsung J700 Cellular Phone
Whirlpool oaisis dryer will pwr on, but when start pushed-clicking noise and dryer won't start. Must pwr dryer back dwn to be able to change any timer setting, but dyer still will not start. ????
Model is 110.6705 Oasis Kenmore elite. Have removed back cover and have found drive belt broke. is there a seensor to shut motor dwn if belt breaks? Will order belt replace and see if thay resolves issue. Thanks
PS
No code given.
Oct 16, 2008 | Whirlpool Dryers
Kenmore Refrigerator not that cold.
How full is the frezzer compartment with product?
Sep 15, 2008 | Refrigerators
Kenmore sidebyside
you are probably getting an ice build up on the evaporator and the drain also blocked with ice. take back cover off freezer and melt any ice off with careful use of a hairdryer. make sure the drain at the bottom of evaporator if free by pouring a little water down it. if blocked with ice, free with hot water and parience. if fault reoccurs, you have a fault on defrost system
Apr 17, 2007 | Kenmore 52673 Side by Side Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
