Question about E-Machines etower 667ir PC Desktop
Drive is saying that my data cd is blank.
The other day i saved all of my pictures & files to a disk
because i was restoring my system. After i burned the
disk i put it back in my drive twice to make sure everything
was copied properly & it was. Now when i put the disk in
to put all of my old data back on my computer it is saying
that the data cd is blank. i tryed putting in a few other cds
to see if they work & it is saying the same thing.
  • 1 more comment
  • JDTec
    JDTec May 11, 2010
    Is it a rewritable cd, if so, did you install the wirting software IE: Nere, Roxio, Sonic?
  • Imre Vetro May 11, 2010
    Are you saying that your drive does not read any data from any of your written cds?
  • Johnny Massengill
    Johnny Massengill May 11, 2010
    What operating system are you using on your computer?
  • 72 Answers
If able update the firmware on you drive and see if that helps. may need to replace the drive
Posted on Dec 05, 2008
Need restore my RAW file system back to NTFS without losing any hard drive files?
Still don't know what you can do to rescue your lost drive files right now?
OK! I have ever followed a video tutorial to resolve solve such hard drive data loss problems from here:
https://www.youtube.com/watch?v=S1F72QPGHm8
You can also check it and follow its steps to see whether all your files could be restored successfully.
In the future, to avoid such data loss troubles, always regularly save your drive stuffs on several places, not only on one hard drive.
Nov 07, 2014 | Seagate Computers & Internet
Windows vista recovery cd I created won't install on new hard drive
Which software did you use to create the recovery disk? Is the recovery disk a CD or DVD?
Just to recover a vista system from recovery DVDs would require at least two DVDs. Your files would be in addition to this so I would be very surprised if you have only a single disk containing both the operating system and all of your files.
A simple recovery disk would only be useful for restoring lost operating system files to a hard disk that had corrupted or deleted files. It would let you restore to a new blank disk.
If the disk only contains a backup of your data then you would need to first install an operating system (Vista or Windows 7) and then install the backup software you used to create the disk and then you could recover your data from the disk.
Jan 05, 2013 | HP Computers & Internet
How do you erase hard drive
A hard drive is the brain of a computer. However, over time, that brain can become overworked and overly saturated with old software and outdated information. It becomes clogged and needs a fresh start. By erasing a hard drive, you can give your PC that fresh new beginning. With a few steps you can erase your hard drive manually, without the aid of expensive software.
Make sure your data is protected before you proceed. Whatever you do not save will be lost once you erase the drive. Use a CD or jumpdrive to save your information. Boot with a system disk. Before you continue to erase the hard drive, use the system to create a system disk. Use a 3-1/2 inch floppy disk and format it with the command "format a: /s"; this will create a bootable disk that contains system commands. Place it in the drive of your system and turn it off, then back on. Reformat the hard drive. Once you've booted with the system disk, type "format c: /s"; this will reformat the hard disk, virtually destroying the old hard drive you used to know. Depending on the of the drive, the formatting may take a fairly long time. Once the formatting is over, use the command "fdisk" to create partitions (which are logical sections for your hard drive's storage). Given the newer hard drives and operating systems of today, you can fdisk the drive and use all of the space. or if you dont have a floppy drive Download a disk wiping utility, such as Darik's Boot and Nuke (DBAN) or KillDisk. DBAN is an open-source product, while KillDisk is available as a free, closed-source download. http://www.dban.org/ http://www.killdisk.com/ Once you download the file, save it to your computer somewhere easy to remember. Insert a blank CD into your computer and use a CD writing program to burn the hard disk wipe utility to the blank CD. If you are using Windows Vista or 7, there is a built-in utility that will perform this task. Back up the data on your computer that you want to save, if necessary. Insert the CD that you created into the computer that is attached to the hard drive you wish to erase. Power on the computer and choose the setup option to boot from the CD. Once you have booted from the CD, you will enter into the hard disk wipe utility. Depending on which utility you chose to use, this screen will vary, but the choice you want to select is to erase or wipe a disk drive. Choose the hard disk that you wish to wipe and confirm that you wish to permanently erase the data on it. Before confirming this, you may wish to physically double check and ensure that you are erasing the correct drive. Once you start the erasing process, it cannot be halted, paused or reversed. You will have to wait for anywhere from a few hours to even a few days for the process to complete, depending on how large your hard drive is.
Hope this helps.
Dec 20, 2012 | Computers & Internet
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
Deleted files after format
im not sure wht you want to do if you want to recover your data/files You could try this software it sounds pretty good although I have not used it so I am unable to direct you on how but it reads as though it has a recover data accidently deleted as well as windows password cleaner and a blank the password utility on any user that has a valid account on windows system and many other tools you might find helpful also listed other freeware recovery programs http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
http://majorgeeks.com/Avira_UnErase_d5284.html
What is gone is gone? Far from it! Avira UnErase recovers data that have been deleted from the hard drive - either accidentally or as a result of a virus infection, an uninstaller or defective software. The danger of important data being lost forever is averted with Avira UnErase.
The private, non-commercial use of Avira UnErase Personal is free
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media.
Oct 02, 2011 | Western Digital Passport 320GB External...
I would like restore my files & system like first day...........but i cant......please help me.........thank you
You need to click on Start (which is located on the lower left corner of your screen ) > Then click on "All Programs" > Choose " Accessories " > Then "System Tools" > Then click on "System Restore" > then choose the date where you want to have your files restore
System Restore will allow you to restore your files on an earlier date provided that you have it save that date as a "restore point"
Another option is to have your important files save in an external drive or flashdrive then have your windows reinstalled to make sure that fresh and clean
Hope this help you a bit. Have great day.
May 18, 2011 | Computers & Internet
My d drive says it is 99% free space but it has 4.53 gb how do i get more gb
Your D drive is usually for system restore. Insteed of system restore disk the manufacturer will partition a drive and place the installation data in the D drive. You should have a C drive and this is where you want to focus on. Delete unwanted pictures , music, and other unwanted files. Movies will really use a lot of drive space.
Nov 03, 2010 | Compaq Presario Notebook
How do recover picture and music files only from hard drive. The computer that it was attached crashed and even when I tried to restore it before it crashed the data would not transfer to the restore point...
Connect the external drive to a different computer, and "browse" the contents of the drive -- if the disk can be read, then the files can be copied, and maybe burned to "blank" writable CD/DVD disks.
May 31, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
WONT BOOT UP, I GET A MESSGE TO START NORAML OR SAFE MODE, EITHER WAY IT GOES 2 A BLUE SCREEN - DO I HAVE 2 REPLACE THE HD?
Since you do get the prompt for normal or safe mode, it means that the system can at least read the boot sector of the drive. It sounds like the data on the drive is corrupted, rather than the drive being bad. There are restore utilities available that could possibly make the drive readable again, thereby fixing the problem without losing your saved files. If you replace the hard drive, not only will you lose any saved files, but then you must also get another copy of the operating system, or buy the restore disks from HP to re-install your system on the new drive. If you do have the system restore disk(s) I would suggest using the repair console first to see if you can restore the system before doing a fresh install.
Feel free to ask questions here.
Dec 06, 2009 | HP Pavilion dv6000z Notebook
E-Machines etower 667ir PC Desktop Logo
29 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
