Question about Sylvania 6313CB 13 in. TV/VCR Combo
Tv shuts off after 10 seconds
Tv screen shows tape setting but no tape inserted
    Problem Solver:
  • 16 Answers
Many times, Cam Gear in VCR gets Stuck due to its age (Loose Belt most time).
Or,
The Cassette Housing is off Track (Usually Bent, or Toys inside!!!)
Solution, if you are not all thumbs,
1) UN-PLUG first!!
2) Get Alcohol Pad Ready.
3) Open Back Cover,
4) Clean the Belt on Worm gear (Usually Side of the mechanism towrds back).
5) while at it, Make sure to Dust with Air Aerosol (like ones that you use for computer)
50% of time this will Fix the Problem!!
Posted on Jan 29, 2009
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
VCR plays 15 seconds, TV shuts off. Same without tape inserted
Sounds like a typical Switched Mode Power Supply fault, or an internal thermal fault that is shutting down the power supply, over & over. Really you need to get it serviced. You need to get a firm "Quote" for repair, remember these days repair can often exceed replacement cost.
Feb 03, 2010 | Televison & Video
I inserted a tape into the VHS slot. It runs through the film but without coming on the screen or any audio. It will not eject the tape. The door opens and closes and it starts running the tape again. ...
the tape is now jammed. stop trying to get it out because it will be destroyed. To rescue the tape now without damage, the tv-man has to open the set and from there un-stick this tape. after that a service is needed in the belts of that machine. The set now is in the middle of this process and maybe this symptom creates the set to shut down after some seconds after because the microprocessor is protecting the complete set integrity.
Apr 14, 2009 | Televison & Video
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Stays on for 5 seconds, thinks it has a DVD or VHS tape in
I am afraid the set has a bad or broken tape transport, or better known as a bad tape carriage.
Jun 20, 2007 | Philips Magnavox 20MC4304 20 in....
TV keeps shutting off after 10 seconds
It's possible from what you described that your center LED or prisim was broken when the tape was extracted. Like many others these units depend on a series of startup checks and one being the tape path. On the play table of the VCR is a center prisim/LED and two light sensitive diodes on either side of the tape loading assembly. If these diodes do not detect the infared beam the unit will go into shutdown. I'd check there and let me know. Bill
Jun 03, 2007 | Sylvania 6319CC 19 in. TV/VCR Combo
VHS carriage stuck
THERE IS A SENSOR SWITCH THAT TELLS THE MACHINE THE TAPE IS LOADED ... SOUNDS LIKE IT IS STUCK. PROBLEM IS ACCESS WITH COMBO'S. THEY ARE A PAIN TO GET AT. THE WHOLE BACK COVER TO THE TV MOST OF THE TIME HAS TO BE REMOVED,... I KNOW ITS NOT MUCH HELP BUT THE MANUFACTURES KNOW THAT... HOPE YOU CAN GET TO THE TRAY INSIDE. Joe_Rex
May 01, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Sylvania 6313CB 13 in. TV/VCR Combo Logo
238 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Dave Naylor
Dave Naylor
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
