Question about Samsung HT-DB120 System
HT-DB120 - PROTECTION due to shorted output stage
I have the same problem on my unit. One day whilst playing for @ 20 min. the system stopped with "PROTECTION" displayed. On opening the unit I could not see any symptoms of the failure, like shorted cap or component and I checked all the power transistor modules with a multimeter and they did no indicate a short. After keeping it for 3 weks I powered it on yesterday only to notice a small whiff of smoke come out near the middle (biggest) power module. However no burning smell, nothing. This tells me that one of the output modules or transistor in the module is shorted. I did not have the time to desolder this and try powering on but this is the cause of the auto PROTECTION trip. Cause: Shorted power output stage that drives the speakers. I will update this as i have time (and patience) to desolder each module and test which one is fired up. Then the next thing will be to get an equivalent replacement transisitor to repair it. Anyone who can add more value to this is welcome to share their "repair" experience.
  • 7 more comments
  • shegoddess Nov 04, 2007
    I try to power on my dvd player but protection comes on automatically and then powers off to stand by. Anyone have an answer to this
  • phunktified Jan 21, 2008
    Same problem: power on, message flashes "HE... PROTECTION", immediately powers off. I'm guessing it would say "heat protection" if the message flashed the first word more slowly? The first time this happened it powered on, I put in a DVD, got the error and unit powered off. Then it would never power on again, and I could only retrieve the DVD by unscrewing the outer casing.
    Called Samsung "help" line - they were NO help as they said they had NO record of this model number!? The system is only about 4 years old, how can Samsung have no record of this model? (I think they don't want to answer recall questions for this model.) To top it off, Samsung wanted $160 dollars to repair the system.
  • Aradan Feb 19, 2008
    Same problem - I tried to unplug all the speakers as someone suggested here but it was no use...
  • lindi21 Apr 14, 2008
    i also have the same problem, unplugging doesnt work, will not turn back on! Please help i want my dvd back!!!
  • Dyester Jan 02, 2009
    same problem here
  • Anonymous Jan 25, 2009
    same as above. I think I'll just salvage the speakers and dump the unit.
    piece o ****.
  • JWcunt Jul 22, 2012
    @phunktified It's more likely that the HE is the start of "HELLO" during power on and then it gets overridden by the PROTECTION message.
I have the same problem. was playing a cd for my son for about 20 mins. CD started skipping then froze up and shut off. When trying to power on the word "PROTECTION" comes on then shuts right off. Is there any solution for this problem? My husband bought this when it first came out over 6 years ago at $400. I bearly even use it. It's a waste to throw away. Please someone help. Thanks.
Posted on Apr 29, 2008
    NOT A SOLUTION
SOURCE:
SAMSUNG HT X30 SHUTS DOWN WITH" PROTECTION"
It's a known issue with samsung Home Cinemas. It has to do with the cooling of the device and other related issues. One of the bellow could solve the problems.
First thing is to reset the device:#1 - Make sure there's on dvds in the system
#2 - Put it on stand by
#3 - Hold down the STOP button on the UNIT
#4 - HOLD until you see the stand-by light flash
#6 - This has now reset the system
If that doesn't work try to do a firmware upgrade http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=HT-X30
Nov 21, 2011 | Samsung Audio Players & Recorders
Tv sony stop after 20 min standby led flashes 3 times
HI,
By three blink it means the B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is because there is problem in the power supply circuit. Check for any dry soldering in the power supply side. If the tv is working properly for 20 minutes then its sure that there is some dry soldering joints in the power supply side. You have to resolder suspected soldering contacts using soldering ion and solder. The dry soldering joints will look like on in the picture.
ajin_g_109.jpg ok
Oct 06, 2011 | Sony KV-29FX66 29" TV
After speaker wire touched. ht doesn,t stay on. it goes into protection as if it is over heating
The output was shorted and probably damaged the output stage of the amp. It's a service shop repair unless you know electronics and can get parts for it....
Mar 03, 2010 | Samsung HT-X40 System
Sony dav dz100. Disc does not spin.
Please put few drops of WD-40 on spindle motor shaft that sound not spin smoothly.
Spindle motor is located in middle of dvd mechanism that holds and spins disc.
If that does not solve your problem, replace optical block.
Let me know if you need optical block part number.
Thanks.
Dec 05, 2009 | Sony DAV-DZ100 System
Protection Error on power up
your cooling fan has failed. Check the back of the unit for exhaust air coming out. If not replace fan.
http://www.partstore.com/
Nov 23, 2009 | Samsung HT-DB120 System
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
Once switched on, PROTECT appears on screeen and system turns off
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-DS1000 System
Protection displayed and shuts off
the solution is get rid of it fast , i had a samsung dvd player that did that then it caught on fire , pretty scary,lucky i was there when it started to smoke up
May 23, 2009 | Samsung HT-X40 System
Unit only displays "hello"
This is a faulty condition caused by lack of error control in the firmware. Try this:
Unplug machine from wall for 5 min. Hold "open/close" button in and then plug machine into mains whilst continuing to hold the open/close button. Keep holding open/close button for about a minute, as these machines are notoriouly slow to "boot". It that doesn't work, repeat the procedure, but hold down the power button instead of the open/close button in an attempt to reset the memory settings of the unit. Good luck.
Feb 08, 2009 | RCA DRC8320 DVD Recorder/VCR
PS3 stopped playing discs
what is up with PS3 anymore? Of course, all these systems are used or as-is but still...
I bought mine at a reputable pawn shop and it played for almost a month and it stopped playin metal gear 4 and college 9...Downloaded he new system update and nothing
Jul 30, 2008 | Sony Playstation 3 (PS3) Console
Samsung HT-DB120 System Logo
712 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
